Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
Modem not power on
Thanks m8 but still not resolve the light flash then go dead the power is good was trying to put the sigma on this morning everything went pretty good then when i reboot i had this problem can u still help?
  • whiteops Jun 18, 2008
    Me too.
    What Should I do?
    The modem is Motorola SB5100
  • 1,031 Answers
What type of modem do you have?
Posted on May 09, 2008
  • Starnley Johnwells
    Starnley Johnwells May 21, 2008
    go to the link http://h10025.www1.hp.com/ewfrf/wc/fastF...
    but you sounds as if the paper sensor flag either got stuck or broken when the paper got jammed - you might have to take it to a shop to get an accurate diagnosis, without seeing it I couldn't tell you more than that....but you can still try this
    , take a piece of ~70lb cardstock, and with the POWER OFF, gently push this through the paper-path of the printer - this will help to possibly reset that switch, and will help push anything else out that's in the way that may be blocking it.
    again check the quality and the type of paper you feed it does it comform this could be one
    the above comment was done in error plz take note its not for the intended user
DIR-815 Signal strength excellent but no internet
Possibly the power outage caused your modem to reset. The wired connection would still work. first thing I would try is to reset the modem with the reset button, login to the management console and put in your network name and password again.
Dec 21, 2017 | ASI Computers & Internet
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
My router has stopped working this morning. The modem router light flashes blue a couple of times then the security light and modem router light up blue for a couple of seconds the all turn off. None of...
TRY RESETTING THE ROUTER. THERE WILL BE A SMALL HOLE IN THE ROUTER WHERE THE RESET BUTTON IS. INSERT TOOTHPICK OR SOMETHING NON-METALLIC AND DEPRESS FOR 30 SECONDS. THAT SHOULD RESET IT.
GOOD LUCK
Oct 19, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
No power on TV - JVC LT-47X788 47 in. HDTV LCD
Power supply board is dead.U have a LED light indicator on LCD panel flashing?The tv is completely dead,no LED light at all?Tries Website like Shopjimmy.com.Ebay.com to buy a refurbish power supply for the replacement.
May 07, 2010 | JVC LT-47X788 47 in. LCD HDTV
Belkin router wireless is good with green lights on, but modem light is flashing. What seems to be the problem?
HI! I believe your having an issue with the connection. if the modem light is flashing. try to unplug the power of the modem for 1min and plug it back in. if still flashing, press the reset button for 20secs. then release, it will turn of and on. after it initialize, unplug the power from the modem for 20secs then plug in, if its still the same, call your isp provider. modem is dead
Nov 24, 2009 | Belkin F5D9231-4 Router
Motorola SB5100 Cable Modem Power Lght Flashes
Call your Internet Service Provider.
They can remotely "connect" to the cable-modem, and diagnose it.
Jul 16, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Green power light is off. Red light stays on. Tried unplugging, resetting, etc. Wondering if it's completely shot?
Hi Jeff,
Thanks for using fixya
The red light on power means that the diagnostic for the modem is on, and when this is on this means that the memory or another component of your modem is at fault. Usually this can be resolved through a firmware upgrade to be applied by 2wire, but note that 50% of the time, when the diagnostic light is on, the device is dead.
To have this issue resolved, you may refer to your ISP or 2wire, if it cannot be revived, the least they can do is provide a recommendation.
http://support.2wire.com/
regards,
voodoo
Apr 22, 2009 | 2wire (1000-400108-001) Router
Bulb replacement for Sigma EF-500 DG Super
So I had fixed the problem this morning, since the warranty has expired, I opened up the flash to take a peak on the inner workings, and found that a wire had come loose, got out the soldering gun and repaired the connection and all is good.
Sep 28, 2008 | Sigma EF-500 DG Super for Canon EOS TTL...
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
103 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
