Question about Haier HWF05XC3 5,000 BTU Air Conditioner
I need to obtain a frame for the RIGHT accordion screen (part #AC-2950-40), but it is listed as discontinued. However, the LEFT frame (part #AC-2950-39) is indeed available. What can I substitute for the part that is not available? Thanks.
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
May 17, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Can i connect two monitors to a nvidia geforce 315 card so as too use two monitors
hi,
yes the 315 desktop card does have multi monitor support. you may however need an adapter for one monitor as it only has one dvi ,one hdmi and one vga.
so you can hook up any 2 as a combination but they have different plug configurations to do this
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Sep 16, 2011 | Computers & Internet
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
My screen is cracked and i am trying to delete the books but it wont work so i am trying to delete it from the computer will it work?
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
BE CAREFUL AND DO NOT DELETE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please rate me
Jan 07, 2011 | PANDIGITAL 7" Digital Photo Frame With...
Window set up for box plot
Use the Zoom button and select 9:ZoomStat. Window will be restricted to your data.
Suggestion: You can use two lists. L1 for the values, and L2 for the frequency. I see many duplicate values: 6 values 23. On the same line as 23 in L1, put 6 in L2
Before entering the frequencies in L2, you may want to sort the L1 list. It would look more orderly.
Other advice (forgive me if you already know). To obtain the median, Q1, Q3 use the [TRACE] button, then use left/right arrow. Screen will display the values for Med, Q1, Q2, Minx, MaxX.
Hope it helps.
Nov 11, 2009 | Office Equipment & Supplies
Constant paper jams
For the accordion jam, open the back panel. You'll see two screws on the left and on the right. Unscrew them and try to take out the part with the small plastic roller out. Clean the rollers. Then you'll see another rubber roller on the ceiling of that part. Clean them with a damp cloth and rubbed them gently. Then screw back the part you took out and close everything back up. That should clear the jam.
Oct 28, 2009 | Brother MFC-7820N Printer
2001 pontiac gran am when turning left there's a
what side the does the noise come from?if right side the right cv axle if left side then left cv axle has gone bad common problem on front wheel drive cars.to make sure look under car and look next to tire there should be a black rubber boot that is accordion shaped if torn there's your problem.
Jul 12, 2009 | 2001 Pontiac Grand Am SE
Favorites center doesn't stay open
Open IE and click on Favorites. When it opens, look for an icon in the upper right corner of the frame. Click on the icon, small green arrow pointing left, to 'pin' the window open.
Good luck and let me know how it works for you.
~ Spoem
Mar 27, 2009 | HP Pavilion dv1000 Notebook
I have a Quantaray 7" digital photo frame by Sunpak. I am unable to adjust the brightness. It stays dark all the time. It was the last one Wolf had and the direction where missing from the box. The screen...
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
Dec 25, 2008 | Quantaray 7-Inch Digital Picture Frame -...
Heating & Cooling Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
