Question about NKOK Halo Hornet RC Helicopter
The bottom blade has stopped spinning. Help - NKOK Halo Hornet RC Helicopter
Ok this is what you got to do you have to take apart the helicopter and in it try to turn the bottom blade you will hear a clicking sound from there you should see whats wrong i had the same problem hope this helps
Posted on Nov 21, 2010
  • badumboom Feb 02, 2011
    The motor powering the lower blade has slid out of position, causing the lower propeller gear to not line up with the motor gear. Take apart the Helicopter, and slide the motor down and back into place
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
I have the 14-Cup Cuisinart Elite Collection Food Processor. Up until recently it was working fine. Recently when using the shredder blade, when I insert food into the feeding tube the blade stops...
If the unit works OK with other attachments and the problem is only with the one cup; then the blade may be loose and spins on the shaft, the connection gear under the bottom is worn or binding up. Debris is stuck around the blade shaft or from heating up the metal parts expanded and bind when turning.
Mar 10, 2014 | Cuisinart Food Processors
After a minimal crash the bottom blade is not spinning , but the whole copter is trying to spin.
probably you bent a piece near the shaft and it is stopping the prop from spinning but since the motor is still spinning it still tries to spin the other side of the shaft(the copter)
Dec 21, 2011 | LawlMart iPhone Apps
The rubber on the fridge & freezer doors are hot
pull out the machine,remove the front bottom kick plate and then go to the back and remove the back bottom panel,check to see if the condenser fan blade is spinning and check the condenser coil to see if it's loaded with lint and dust.the fridge is running to hot,the way it cools down is the condenser fan blows air around to keep the machine cool and heat escapes through the condenser coil,if it's blocked with dust the heat is held in the coil,a shop vac works great for the coil,vac up as much dust as you can and then set the vac up on blow and blow the dust out of the coil,the coil will either be in the back or on the very bottom of the machine,if the fan isn't running try spinning the blade,it might run or something could be stuck in it,i've found from a piece of paper to a mouse stuck in the blade,if it is the blade you can leave the back panel off and stick a house fan back there to cool down the machine until you get a new motor,if the motor does run after you spin it i would still change it out as soon as possible,if it stops again you could damage the compressor and then it's new fridge time.you should clean the coil at least once a year.hope this helps and next time you need help send the brand name and the model number off of the machine that you need help with
Nov 12, 2011 | Refrigerators
Motor works but blade does not spin. When I press down the glass while motor is running, it will spin a tiny bit but then stops.
check the interlocking part on the bottom of the blade piece. This part can wear down and then not interlock properly therefore it does not spin anymore. You can buy a new one from the website but it costs $30 and it comes with a bunch of other stuff. It's called the deluxe upgrade kit.
http://www.buythebullet.com/
May 11, 2010 | As Seen On TV Magic Bullet Food Processor
Was vacuuming coils/bottom of fridge and my brush hit the fan and now fan is not spinning. Does the fan always spin or only when called for??? HELP HELP
If the compressor...the black can in the back...is running then the fan should be running...
if it is not running when it should be, check the fan baldes, you may have bent one or more of the blades and now the fan is stuck because it cannot turn...
If so, just bend the fan blades back stright so they do not hit anything...
heatman101
Apr 25, 2010 | Refrigerators
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
NKOK Halo Hornet RC Helicopter Logo
488 people viewed this question
Top NKOK Toys Experts
Andrew Taylor
Andrew Taylor
Are you a NKOK Toy Expert? Answer questions, earn points and help others
