Question about Whirlpool AWZ410 Front Load Washer/Dryer
Inlet valve cleaning
How do I clean the inlet valve?
    President:
  • 1,294 Answers
You can't.
Posted on May 10, 2008
Not heating water
see this causes and fix it. God bless you
Water Inlet Valve
First you will need to completely remove both hoses. Check and clean the screens in the hoses. Next look in the back of the water inlet valve the screens can usually be pulled out and cleaned. If all is clean and still no water, check to make sure the water inlet valve is getting power when the washer is in a fill cycle. If it does replace the water inlet valve.
Sep 28, 2012 | Washing Machines
Rinse cycle not much water
see the next steps and use the common sense:God bless you
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control.
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Aug 01, 2012 | Roper RAS8445KQ Top Load Washer
GE washing machine Toploader will not fill with water
see this causes and remedies: God bless you
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control. see the diagram attached
Control / Timer
Jul 18, 2012 | Washing Machines
Dishes not coming clean
Check water inlet valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
How to test a dishwasher water inlet valve.
How to replace a dishwasher water inlet valve.
May 26, 2011 | Maytag Dishwashers
Cold water rinse takes hours to fill
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.Replace the water inlet valve with this part.
Dec 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
NO WATER IN ANY CYCLE. WATER LINE OK.
Hello
If you have already checked the water line for clogs and its clean then its the water inlet valve thats causing this problem. Please try to clean the inlet screen for any clogs and hope you understand if cleaning won't solve the issue then recommended repair is water inlet valve replacement. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Kenmore Dishwashers
My amana lw9103 fills cold water very very slowly. I just checked inside the hose and it is clean. What can it be?
The inlet filter is blocked or the inlet valve is faultyand not opening as required. So trace the valve at the inlet of the water hose , you can see a filter attached to the front end.
now clean and set the filter, if not check the voltage on the valve , if low check controller, if not the valve can be cleaned or replaced accordingly
Sep 27, 2010 | Washing Machines
How do you easily clean inlet valve?
First check if your faucet has good pressure (clean small screens); if this does not solve your problem simply change your inlet valve.
May 04, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Whirlpool AWZ410 Front Load Washer/Dryer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
