My tv remote has stoped working can i buy a new 1 or do i need 2 buy a new tv
  • 298 Answers
Whats the model number of your TV?
Posted on Aug 31, 2010
LCD2710HDAF television will not respond to remote control
Hi Alan,
Here are a few steps to troubleshoot.
1) Make sure that the new batteries are correctly installed.
2) Make sure that there is a line-of-sight between the remote and the TV while operating.
3)Not recommended- but might work. Give your remote a little shake. If there is a small circuit loose connection it will be adjusted. :P I do this all the time.
4) Buy a new remote. You can buy a universal remote which are available on the market. They are cheap. It will NOT be harmful to your TV.
OR
you can buy a genuine one.
May 12, 2014 | Televison & Video
Bad Remote
try this: 1. change the batteries in the remote, 2 make sure the terminals inside the remote are clean, 3. if possible try opening the remote there my be some damages inside the remote, 4 borrow the same remote to a near friend to see if i works with your Tv, if it works then you need to repair yours all buy a new one
Jun 25, 2010 | Samsung DLP HL-P5663W 56" TV
We have a One for all TV control. It stoped working
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Televison & Video
My sanyo tv has 2 video outputs but the only way to switch to video is by remote but it don't work.
Change ur remote bateries,and clean the IR on the remote and tv.If still don't buy a new at 1-800-Original Factory remotes.
Aug 17, 2009 | Televison & Video
My lifestyle12 remotecontrol stoped working
You can purchase a replacement remote from one of the sellers below, or use an universal remote.
You may need to find codes with auto detect if using an universal remote.
Replacement Remotes
1-800-Remotes
TV VCR DVD Stereo Remote
Best Replacement Remotes
Remote Controls Incorporated
123 Remotes Replacement Remote Controls
Mar 21, 2009 | Bose Lifestyle 12 System
Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Aug 10, 2008 | Panasonic DMR-ES35VS
Ilo hd tv
Hey try unplugging your television and taking the batteries out of the remote control.. Wait about 5 minutes and try it then! Did that help? If not, your remote control code be broken or it could be your television, but most likely the remote, so I would recommend purchasing a new replacement remote control from a site like http://www.remotecontrolscenter.com instead of buying a universal remote control that you'll have to spend hours trying to program to work with your tv, instead the replacement remote will be an exact replacement for that broken remote control. Hope that helps!
Sep 06, 2007 | iLO V27DMBX Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
