Question about Hitachi CP-X260 LCD Projector
Hello, My projector has approx 400 hours of run time. It will not project any hues of red. Any suggestions?
  • 21 Answers
Does it show red hues without any devices connected to it? If the colors are fine without an input device, the problem is your cabling or a connection. To check these, do the following:
1) Disconnect all your cables and observe the ends to make sure they are undamaged. If they look good, reconnect them.
2) Flex the cabling, moving a few inches at a time, starting at one end and moving slowly to the other while watching the projected image. If you see any change, you have found a damaged cable and need to replace it. If nothing is found, then try step 3.
3) Replace your cables with any spares you might have. If this does not fix the problem then go to step 4.
4) Go into your projector menu and find your color settings. Try adjusting these to see if you get the red hues.
If none of the above provided a helpful solution, The problem is usually the internal color panel. The last time I had one of those repaired it cost about $2000. If you are not very experienced repairing electronics or electronic components, you should not attempt this.
Posted on Apr 08, 2011
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
Panasonic projector Pt-LB60u has a greenish hue around part of the edge of the projection. What would be causing this?
upon the bulb life running out on pani projectors and proj. tv's the lamp set will start to produce a green hue get a new lamp bro. try this web site i highly recomend them www.electrified.com
Feb 08, 2010 | Panasonic PT-LB60U Multimedia Projector
Green verticle line on right side of image
Your color convergence is out of adjustment. You can adjust yourself with a service manual telling you how, or take it to service shop and pay about $400.
Jan 17, 2010 | Sanyo PLV 60HT Multimedia Projector
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Yellow/green hue on projection
the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine.
Jun 02, 2009 | Toshiba TLP T50MU Multimedia Projector
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
RCA D52W136D blurry screen
This is a rear view projection television. Inside is a projector with three lenses (red, green, blue). The projector only has a fixed number of hours in it's lifespan and then it dies. You either need to replace the bulbs, or replace the projector. Both options will most likely be more than $400.
Your technician shouldn't have to come out to your house. The back panel can be removed from the TV, and the entire projection unit slides out on rails. You can put that in a car and drive it wherever you want to get it repaired. That might save you some money.
Dec 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Sep 07, 2008 | JVC AV-56WP74 56" Rear Projection...
4805 w/less than 300-400 hours has blinking red light
Yikes. I bet the bearing is bad in the fan and/or the fan is rubbing up against something. It might be an fix.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
PD523 no picture, led blinks
Hy !
Seems to be the colorwheel. When a segment is broken, the unbalanced wheel causes vibrations. Costs approx. 100-150$. Take away back and top so you can see if wheel is not complete.
Good Luck!
Jul 07, 2008 | Acer PD523 Multimedia Projector
Hitachi CP-X260 LCD Projector Logo
61 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Electro Med Services...
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
