Question about LG WM-2277HW Front Load Washer
Good Morning Sir/Ma'am, We own an LG WM2233HW with an "error code of OE" which means "Drain hose is bent or clogged" and/or "The drain filter is clogged". I have checked both. I straightened the drain hose in the back and even tried to fish out any clogs with a straightened metal coat hangar with no findings. I checked drain filter only to find it clean and empty. I took apart the drain pump and cleaned out the pump from debris/gunk/and hair wrapped/tangled around the pump. I put everything back together and still to no avail. The machine machine is just still at the draining phase right before the drum would start its spin cycle. Just looking for some more ideas before I have to call a repair tech. and spend $400. Any help or advice would be appreciated. Thank you.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are right OE error is caused when the washer is unable to drain for 10 minutes. As you have already checked and cleaned the drain hose and it seems that you have cleaned the drain pump filter & still the issue is not resolved then it seems that the pump has gone bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Good Morning Sir/Ma'am, We own an LG WM2233HW with
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!! !
Posted on Sep 18, 2010
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
OE error on washing machine LG WM2233HW
LG themselves have some information on this error code.. CLICK HERE
Thanks
Oct 12, 2011 | LG WM2233H Front Load Stacked Washer /...
Getting a "oe" error how
See
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
Good Morning Sir/Ma'am, We own an LG WM2233HW with an "error code of OE" which means "Drain hose is bent or clogged" and/or "The drain filter is clogged". I have checked both. I straightened the drain hose...
Aug 30, 2010 | LG WM2233H Front Load Stacked Washer /...
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
For LG WM2233HW, Error Code OE. Already check drain hose and filter, all clean. Try different cycles, TUB CLEAN, SPEED WASH. Same error code. No drain.
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Jun 19, 2009 | LG WM-2277HW Front Load Washer
LG Washer/Dryer won't drain
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Wht does the code OE Mean I can't find my manual for my LG 2077 washer
HI. this code represents a drainage problem. The drain hose may be bent or clogged with debris or, it may be a clogged drain filter as well. I recommend cleaning and straightening the drain hose and i would also clean the drain filter. this should fix the issues you are having with this washer.
please rate and god bless.
Mar 24, 2009 | LG WM-2277HW Front Load Washer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
171 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
