Question about Whirlpool Kitchen Ranges
Whirlpool Gold Accubake System smooth top stove keeps kicking out the 10 amp breaker, sometimes with oven on, sometimes just a burner on, just started doing this a week ago, why????
I have had teh same issue. Not sure if its a design issue or that is just how it works. I have replaced the element, the thermostat and the control board and it still does the repeated cycling.
Posted on Sep 20, 2010
When oven circulating fan is on there is a virbration. how do you locati the fan?
Fan is located in rear of stove or maybe a piece if foil paper for into blades
Jan 05, 2015 | Whirlpool Gold GY399LXUB 30" Slide-in...
I have no power to oven or burners. Where are the fuses located
there would be no fuses in the stove itself. Try the house breaker or fuses to the stove.
Sep 20, 2014 | Whirlpool Accubake RF362LXTT Electric...
My stove made this zapping noise, sparks came out the bottom and then tripped the breaker.
You need to have the stove looked at by a qualified appliance tech. The fact that the stove sparked and tripped the breaker indicates a short some where in the stove and it is very unsafe to use it. Leave the breaker off until you have the stove serviced.
May 23, 2014 | Whirlpool Gold GW397LXU 30" Slide-in Gas...
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
My Whirlpool Gold Accubake, smooth top displays E1 - F1 (blinking). I am unable to utilize the oven because the push-button/ touchpad does not work however the electric burners work fine. Any clue? Many...
Hello, Thank You for using FixYa. I will be helping you today.This is erc or control failure. You would have to replace the electronic range control sometimes called the clock depending on your model number
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Ovens
My oven and stove top isn't working at all. If I turn a burner on, the clock and oven light up, but the burner doesn't get hot and either does the oven. It's only 8 years old and isn't used often.
I was having this problem and it was because I had tripped the breaker. Reset the breaker (box Inside your home) and try that, However, there is probably an underlying electrical problem that should be fixed asap. I live in an older remodeled mobile home that isn't equipped to handle a lot of appliances going at the same time. Try to make sure you aren't pulling so much power when you use the stove, ex: TV, microwave, oven, stove, all running at the same time.
Nov 19, 2010 | Whirlpool Accubake RF362LXTT Electric...
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold accubake system stove/oven
Can you unplug the plug for a while? Are you the new owner ?
Do you have home owner insurance?
Jun 24, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchen Ranges Logo
329 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
