Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
When I start my computer it buzzes at me and the number 1 light stays on. I have tried removing and reintalling memory modules to no avail. This has been happening for months, but now it won't boot at all.
  • 355 Answers
HERE is a link directly from Dell to what the diagnostic lights mean and possible solutions. Looks like it may be a memory issue but further troubleshooting will tell. Dell is usually pretty good about support even if you PC is out of warranty. At the very least they can help you diagnose the problem.
Posted on Aug 31, 2010
Power light amber with code 3 and 4
Looks like Memory Issue,
Memory modules are detected, but a memory power failure has occurred.
You can try as follows :
  • If two or more memory modules are installed, remove the modules, then reinstall one module and restart the computer. If the computer starts normally, continue to install additional memory modules (one at a time) until you have identified a faulty module or reinstalled all modules without error. If only one memory module is installed, try moving it to a different DIMM connector and restart the computer.
  • If available, install verified working memory of the same type into your computer.
Let me know
Thanks
Feb 18, 2014 | Dell OptiPlex 780 PC Desktop
Dell xps 200 installed new hard drive
I share information HDD back site small jumper available so you attach 1-2 and CD back side available jumper not connect any pin. Mother board auto find it and not any issue ok.
Thanks.
TechSupportMart Computer Support
Feb 14, 2014 | Dell Dimension 3000 PC Desktop
My dell optiplex gx620 does not start and it shows no. 3 and 4 lights illuminated on its front . what could be the problem.?
One of your memory chips is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Diagnostic Lights caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. To help you troubleshoot a problem, your computer has four lights labeled "1," "2," "3," and "4"on the front or back panel. The lights can be off or green. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. If the POST portion of system boot completes successfully, all four lights display solid green. If the computer malfunctions during the POST process, the pattern displayed on the LEDs may help identify where in the process the computer halted.
note.gif NOTE: The orientation of the diagnostic lights may vary depending on the system type. The diagnostic lights can appear either vertical or horizontal.
Light Pattern
Problem Description
Suggested Resolution
The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
The diagnostic lights are not lit after the computer successfully boots to the operating system.
Plug the computer into a working electrical outlet and press the power button.
A possible BIOS failure has occurred; the computer is in the recovery mode.
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
A possible processor failure has occurred.
Reinstall the processor and restart the computer.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see "Memory" for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell.
A possible graphics card failure has occurred.
  • If the computer has a graphics card, remove the card, reinstall it, and then restart the computer.
  • If the problem still exists, install a graphics card that you know works and restart the computer.
  • If the problem persists or the computer has integrated graphics, contact Dell.
A possible floppy or hard drive failure has occurred.
Reseat all power and data cables and restart the computer.
A possible USB failure has occurred.
Reinstall all USB devices, check cable connections, and then restart the computer.
No memory modules are detected.
Memory modules are detected, but a memory configuration or compatibility error exists.
An other failure has occurred.
This pattern also displays during System Setup and may not indicate a problem.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • Check the computer message that appears on your monitor screen.
After POST is complete, all four diagnostic lights turn green briefly before turning off to indicate normal operating condition.
None.
Jun 06, 2012 | Dell OptiPlex GX620 PC Desktop
ProLiant DL160 G6 Server, Part Number 593352-B21, Serial Number USE029N5Z2. The system fails to power on. The power supply has the LED light green. The start button does not turn amber. Do not...
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Aug 04, 2010 | HP ProLiant DL160 G6 Server - 1 x Xeon...
On start up i have lights 1 and 3 lit up only and a periodic buzzing noise from inside the tower (every couple of seconds). after about 15 seconds the buzzing stops, the lights stay on and nothing else...
The problem is due loose memory sticks or mismatched memory sticks.
You need to open the computer tower and reseat the memory modules on the machine to fix the issue.
How to do it ? follow the link below
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
Thanks for using fixya
proton
May 19, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I put the power on my pc, the monitor stays black, i push the power button on my monitor and the button goes green for a few seconds and then back to orange as if it is on standby mode. i can hear the pc...
The lights you see flashing are Diagnostic Lights. These tell you of a possible area to look into for the problem.
Lights 3, and 4 flashing green, mean a possible Ram Memory problem.
I would like you to view the free Owners Manual from Dell Support, in the event that you do not have one.
http://support.dell.com/support/edocs/systems/dime521/en/index.htm
This PDF document can also be saved to your computer, thereby allowing you to copy it to a CD disk. If you are not aware of how to do this, and wish to, simply state so in a Comment.
(After you burn this PDF file to disk, you can remove it from your computer, freeing up more space on your harddrive)
Where it states Owners Manual, left-click on View to the right.
You may also be interested in viewing, (And copying), the Service Manual.
What I would suggest to start.
1) Computer off, unplug your computer from power.
Working on a table, open the computer case.
TOUCH the metal frame of the open computer case.
(Not shouting)
This action will relieve your body of Static electricity.
Your body carries Static. Static will fry out (Short Circuit) computer hardware components.
(Should you get up in the middle of working on your computer, and leave, upon your return Touch the metal frame again)
Remove all ram memory modules. (Ram Module = Ram 'stick')
Use a pencil eraser, and clean the gold plated contact pins on the bottom of the ram module.
This is a photo of a basic ram module,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Here, you can see the gold plated contact pins I have referred to.
(Ram Memory used for the Dimension E521 Desktop PC, is DDR2 Sdram.
DDR2 Sdram has 240 contact pins. 120 on each side.
The photo is of DDR Sdram.
184 contact pins, 92 on each side)
If possible, it is preferred to hold the ram memory module by the body of the module, and refrain from touching the contact pins. The body of the ram memory module is covered by a see-through plastic.
Start at the top of each contact pin, and work down, using the eraser.
Remove the eraser dust with air, and reinstall.
If you have two ram modules, try inserting one at a time.
The ram slot closest to the Processor, is Ram Slot 1. (May be marked as DIMM 1 on the motherboard)
Ram memory should be installed in ram slot 1 first.
The Processor reads ram memory installed in ram slot 1 first.
In the Service Manual if you click on - Technical Overview in the main menu, then click on - System Board Components, you'll see where the Processor
is located, (2 - processor socket), and where the ram memory slots are, (3 - memory module connectors)
Removing and Installing Parts, located in the main menu also, will show, and tell you how to open the computer case, and how to remove, and install ram memory modules.
(Removing the computer cover. Memory)
Should you need more in-depth guidance of how to do the above, please state so in a Comment.
Should this not fix your problem, please state so in a Comment.
Apr 14, 2010 | Dell Dimension E521 PC Desktop
My Dell Optiplex GX520 will not boot. There is no video output and the 3 and 4 diagnostic lights remain on.
If 1 & 2 are off ... then you have problems.
  • If you have one memory module installed, reinstall it and restart the computer. (see Memory for instructions on how to remove and install memory modules.)
  • If the problem persists, contact Dell (see Contacting Dell).
According to Dell's notes:
Their remedies are:
Jun 17, 2009 | Dell OptiPlex GX520 PC Desktop
INSTALLED 1 GB MEM STICK AND NOW COMPUTER WON'T START?
The memory module you installed may not be the correct type. Try removing it and if the computer starts fine after that, the memory is either wrong for your computer, or it is a bad module.
Go to www.crucial.com and run their memory scan tool. It will tell you the exact type of memory your computer uses. Compare that information to the sticker on your memory module.
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
When I start up my computer, the screen stays black. However, the light flashes indicating that it is working, and the computer makes the starting sound.
Test your notebook with an external monitor attached to the VGA port on the side of your notebook. If both internal and external monitors have no image, this problem is not related to the notebook screen.
It could be memory related problem. Try reconnecting the memory module. If you have two modules installed, remove them one by one and test the laptop with each module separately. It’s possible that one of the memory modules is bad and your notebook will start as soon as you remove bad RAM.
Jan 09, 2009 | Dell Inspiron 1521 Notebook
When i turn my computer on, it gives two long beeps, the machine is on but the screen stays blank, as though its on sleep, what do i do?
Two long beeps is the code for memory trouble. Try removing the memory modules from their sockets. Make sure the sockets are free of dust (computers can get pretty dirty inside), using compressed air (available canned from office supply places, Wal-Mart, etc.) to blow them out if needed. Make sure the contacts on the modules are clean. You can use a pencil eraser with light pressure to clean them off. Reseat the modules firmly in their sockets. Then try restarting the computer.
If the trouble continues and you have more than one memory module in the system, try replacing them one at a time and restarting the computer to try to determine which one is causing the trouble.
If the trouble still won't go away, see if you can borrow a known good memory module from someone and try that. You might have a failed system board or multiple bad memory modules. (It can happen, and can drive you nuts when you try the "one-at-a-time" trick. I've been there!)
Hope this helps!
Nov 19, 2008 | HP Computers & Internet
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
312 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
