When I press the Power on button it does diagnostics and reports processors hard disk etc. i get "Cannot_Find_String" and nothing else happens - just a blank screen.
  • 3 Answers
Re-install the OS using safe mode to gain access to Boot sequence, you'll grow old and grey trying to figure this one out.
But before you do that.......
........( Put the hard drive into an external drive case and extract all your important files )
Then start anew.
Labradt.
Posted on May 08, 2008
Tip
How to defrag your hard drive in Windows XP 1. Open My Computer 2. Next right...
<span> How to defrag your hard drive in Windows XP<br /> <br /> 1. Open My Computer<br /> <br /> 2. Next right click and select Properties on the drive that you want Defragment.<br /> <br /> 3. Click on the Tools tab<br /> <br /> </span><img src="issken_16.PNG" /> <br /><span> 4. Click on the Defragment Now button<br /> <br /> 5. Select the drive you want to defrag if you computer has more than one drive and click on the Defragment button.<br /> <br /> </span><img src="issken_17.PNG" /> <br /><span> 6. When the Defragment complete you will get a message that states "Defragmentation is complete for:". At this point you can click ether on the on the View Report button or the Close button.<br /> <br /> </span><img src="issken_18.PNG" /> <br /><span> If you click on the on the Close button you will be taken back to the Disk Defragmenter Window. However if you click on the View Report button this will open of the Defragmentation Report. This report will show the stats on the drive after the defrag and any files that were not defragmented fully.<br /> <br /> </span><img src="issken_19.PNG" /> <br /><span> You can print the report or save it you a text file your future reference. After you are done with the report click on the Close button.<br /> <br /> 7. When done with Disk Defragmenter utility click on the "X" in the upper right to close the utility.<br /></span>
on Feb 10, 2011 | Computers & Internet
12/24/2012: XBOX 360/RB3-WIRELESS FENDER MUSTANG PRO-GUITAR: WON'T PLAY "FRET NOTES"
If your guitar was not purchased new (since it was hard to find these guitars late in the life cycle) then perhaps it was already faulty before you received it.
Dec 25, 2012 | Mad Catz Rock Band 3 Wireless Fender...
Had bluescreen a number of time, but laptop always booted up again. However i now have a black screen and nothing will boot up,even tried the dell recovery disc, but nothing. Any ideas?Thanks
Dell includes a series of tests for a system's hardware into the BIOS called the PSA+ Diagnostics. You can run these tests even if the system lacks any media (hard drive, CD drive, etc.). To launch the PSA+ Diagnostics on this system, perform one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dellâ„¢ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • If all tests pass you will need to re-install the operating system software.
Sep 01, 2011 | Dell Inspiron 1501 Notebook
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
I was doing an "update" and when it asked to
Sounds like your update went didn't work right. This could have been caused by a corrupted update file that Vista tried to install or you might have a hardware problem (i.e.bad hard drive). Try running the Dell diagnostics. Do you have any CD's thatcame with your computer? If so, look for one that has "Diagnostics and utilities"listed under the "Contents". You will have to boot from that CD disk. To dothis, power on your laptop and tap the key to bring you to the "Onetime boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Next select the "Express Test" and see if any errorsare detected. If no errors are reported, then your operating system software isprobably the culprit.
May 15, 2011 | Dell Inspiron 530s Desktop Computer
I have a slimline ps3 and my hard drive was corrupted so i downloaded a new system update it installed the update it let me adjust the time and date settings and just before it goes to the screen that...
  1. KINDLY REMOVE THE HARD DISK FROM THE CONSOLE
  2. LOOK FOR AN EXTERNAL HARD DRIVE PACK
  3. PUT THE PS3 HARD DISK INTO THE EXTERNAL HARD DISK PACK
  4. CONNECT IT TO YOU COMPUTER
  5. AND FORMAT IT.
  6. REMOVE IT FROM THE EXTERNAL PACK
  7. PUT IT BACK INTO THE PS3 CONSOLE AND TURN IT ON.
  8. IT WILL ASK FOR UPDATE
  9. THEN YOU UPDATE IT.
  10. IF AFTER DOING ALL THIS AND IT DOSEN'T WORK
  11. CHANGE THE HARD DISK INSIDE THE PS3.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
My laptop wont turn on properly, or really at all. when i turn it on the page comes on which says dell.com, that blue bar at the bottom loads and thats it.. its stays on but nothing happens. what could be...
There could be damage to the Boot Sector files or a problem with the hard disk drive.
First run diagnostics on the hard drive (Fn Key plus the Power Button) see if the hard drive fails diagnostics. If it fails the diagnostic, then replace the hard drive. If it passes, boot to your Windows XP CD, enter recovery console by pressing R at the 1st prompt, then run the command: CHKDSK /R <enter>
Dec 18, 2009 | Dell Latitude D600 Notebook
My Dell inspiron 1501 went to a blue screen and gives me an error message when reading the Hard Drive upon boot up. I am told the disk is either malfuntioning on logic or may have crashed. How can I find...
fortunately dell has built in diagnostics that can assist you with identifying the problem. here is a link on how to run them. if the drive is bad then you would need to replace it and reinstall windows and drivers. if it is good then run memory diagnostics as well just to be safe. if both pass then you may have to do a destructive reinstall of windows because you most likely have a virus issue. copy and paste this link into your browser it will help you run the diagnostics.
http://www.cs.utexas.edu/~deke/laptopsupport/manuals/d600/diag.htm
hope this helps
Dec 10, 2009 | Dell Inspiron 1501 Notebook
Compaq Presario SR1000 desktop boot up problem
nothing to do with the ram ... this motherboard sometimes locks, ( dont ask me why) but if you take out the power cord for 5-10 minutes and then press and hold the front power button on the machine (about 10 seconds) it will reset the board. Plug in the power cord and the basic items, sound, video etc ( some usb devices tend to stop it booting to) boot into windows. Then add the rest of your usb devices ..
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
