I have a Toshiba rear projection TV (Model TP43H60, Chassis: TAC9859, Mfg 1998) when I plug it in (to A/C) I hear a click on the power supply and the front power button flashes. There is no display or audio. Thinking the power supply is out but the fuses are Skiff anyone has an idea I'd appreciate it. We had no problems with it prior to this happening; it's a total mystery to us. It was, literally, working perfectly the night before then nothing when I tried to turn it on the next morning, the power light continues to blink red and there is no picture or sound. I can't turn it off either unless I unplug it?? If I replacing the STK ICs, If I replacing it with the substitute IC STK392-110 will be comparable with the original which is look same but has a S letter on the end. Original are STK392-110S and the Question is if the STK392-110 will be Ok??
  • 8 more comments
  • dezsoed Aug 30, 2010
    Thanks for your info will testing out the Power supply again but visually look ok no puffed capacitors ot blown fuse ??
  • dezsoed Aug 31, 2010
    Just tested on the Power supply all four fuse are Ok,F889 3.15Amp, F890 2Amp, F850 5Amp, F470 Amp...I think must be have other two but noy located it on this board.
    This Tv worked fine was one week away unpluged and after a week back from vacation [luged back ,got a Blinking Red power light and no Pic or Sound.???
    Just was one week unpluged from the Power (A/C from the wall) ,when back from the Vacation pluged it back,got no pick no sound just the blinking red Power light. but before worked fine without any problems.??
    Was disconected from the wall (A/C) one week vacation pluged back got a blinkin Red light power On. but priror worked flawlesly no problems with it.!!
    I have a Toshiba Projection TV Model: TP43H60, Chassis: TAC9859, Mfg 1998) when I plug it in (to A/C) I hear a click on the power supply and the front power button flashes. There is no display or audio.
    Thanks SD TECH tomorrow will take the STK out wil see what goin on,,Just retested the Power supply look Ok.. I'm here on the Eastside in Ontario (Oshawa) Canada. Will reporting back to you,
    Regards
    P.S.
    Where i can get a Schematic for this Chassis:TAC9859 Model TP43H60
    Done we you said took out both STK Chipss got the power on Video is back in bloor screen. Therefore one on the STK Chip are blown or short,,the new part are on the way,,will installing the new set of STK's may take other few days to get it ,,,there after I'll posting back to you.
    how it I made out..
    Thanks for help.
    best regards
    Dezsoe
  • dezsoed Sep 14, 2010
    Hi,Sorry for the delay, just today got the IC which I soldered to the Board, WORKING PERFECT!!
    You pointed me to right direction!! Thanks Lot
    Dezsoe
    Perfect! Help pointed me to the rigth direction.. Thanks....Dezsoe
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
A few suggestions here---The S does not mean anything.
Are the chips as you look from the back on the board on the far left facing the front of the set?
To determine if the chips (which can) are causing your problem, unplug set, mark all the plugs on that board and remove the board--now unsolder all pins on both chips (18 each) and put board back, if it comes on convergence will be very bad but you will KNOW if the chips are bad.
I can offer instructions on what to do. STK-392-110 CHIPS are used in many sets---they are fine, if you find they are bad and want to upgrade use STK-392-150, NOTHING ELSE.
Taking the chips out of the circuit will tell you if one of them is bad. Most of these sets use two voltages to the chips protected by pico fuses (not usually glass) if one is blown the set detects no voltage and also shuts down.
If you are lucky and take them out of circuit and set comes on you may just have to replace both.
Keep in mind I am in California and available here from 10 - 9 pm pacific time.
Let me know if you have questions by posting a comment right here.
SD TECH
Posted on Aug 31, 2010
  • 4 more comments
  • SD Tech
    SD Tech Aug 31, 2010
    The 3.15 amp ones are for convergence. The only way you are going to KNOW if one of the STK chips is causing this is unsolder both of them! Completely unsolder so no pins from either chip are connected to the board.
    SD TECH
    Done we you said took out both STK Chipss got the power on Video is back in bloor screen. Therefore one on the STK Chip are blown or short,,the new part are on the way,,will installing the new set of STK's may take other few days to get it ,,,there after I'll posting back to you. how it I made out.. Thanks for help. best regards Dezsoe
  • SD Tech
    Since I pointed you in right direction, remember to rate this solution as very helpful.
    Chips out and set comes on means one is bad, be sure to clean old heat grease and replace with new when you do this.
    SD TECH
    Sorry, just now I'm back just today received the new IC which I soldered to the Board.Working PERFECT, Thanks again to pointed me to the right direction,,,jus a question where i Can give nice positiv Feedback for you ????
    Dezsoe
  • SD Tech
    SD Tech Sep 14, 2010
    Yes, rate it very helpful--that is 4 thumbs up. glad it is working for you.
    SD TECH
    Just was searching here we I cant put up a rating or Feedabeck for you here ?
  • 4,234 Answers
There is no indication that the STKs are the problem yet. This should be fixable, but we need a little more info first. Can you update this with the model number please? Armed with this info, I should be able to provide you with some potential fixes.
Thanks,
Dan
  • SD Tech
    IT is ok, no rating is better than "somewhat helpful" which is what you rated the other two solutions offered here.
    If you got it working that is good enough for me
  • 11,800 Answers
The power led blinks because the source is in protected mode - there's a fault/short on one of its exits and the protection inside the power source has shut it down.
What that fault is can only be found by opening the tv, but on one of this age the capacitors are the first things that pop in my mind. The STK IC's from the convergence board are the second so replacing them is a good idea. Yes, you can use these, the S is there to notify that the circuit has an insignificant improvement over the standard IC - smaller polarisation current. needed)
Posted on Aug 30, 2010
How much was this tv sold new toshiba tp43h60
Original price of this model was around $1700.
Bill W
integrityhomeworx.com
Mar 09, 2011 | Toshiba TP43H60 43" Television
Sound but no picture
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Aug 11, 2007 | Toshiba 43AX60 43" Rear Projection...
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Toshiba big screen tv. tp43h60
Good Day;
I would suspect the convergence IC's, to confirm this unplug the convergence yoke, all three. If TV comes on IC's are bad. Also, check the little green pico fuses. Good Luck, big IRISH.
Nov 10, 2008 | Toshiba TP43H60 43" Television
Please help me
This may be that the power supply has failed, or there is a short somewhere. Many times, the problems occure in the scan amplifiers and in the power supply.
The set will require shop service to get it working again. Considering the type of set and age, I would be seriously considering a new LCD or Plasma set. Your set may be fairly expensvive to service, and with its age its reliability will be lower.
Jerry G.
Jun 13, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba TP43H60
You need to trouble shoot your power supply. There is a toshiba power supply and shutdown circuit troubleshooter available for your model at the following link for 10.99 They will also provide free unlimited assistance after you purchase a manual. They will either mail it or email it. If you'd like it emailed you must return to the site after purchase and click on the contact link and request that they email it along with the info on how to obtain the free support. just provide the email address you want it sent to. Hers the link. http://servicemanuals.vstore.ca/
Dec 31, 2007 | Toshiba TP43H60 43" Television
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Toshiba tp43h60
You have a bad regulator IC or something in the seweep power supply is blow out. if you can read a schematic, i suggest you get one to troubleshoot the solid state circuits in this TV set. if you do not have any solid state repair experience or no electronic background, play it safe and call in a pro to assist you in the repair of this TV set. Good Luck.
Mar 17, 2007 | Toshiba TP43H60 43" Television
Televison & Video Logo
Top Televison & Video Experts
