Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a Dell Dimension 5150 with a P4 3.0GHz and 3GB DDR2 Ram. About a week ago it started shutting down...cold. Not a Windows shutdown. It is like someone unplugs the power. It will then start booting again. It will restart sometimes, but most times it will keep doing the same thing. If I leave it set for awhile, it will come up for an hour or 2 but then do the same thing. I checked the power supply (w/o a load) and it seems OK. I tried jumping the Pwr On line in the main power connector, but still does it. I tried removing some RAM. I looked at the front panel assy. and checked the switch. It seems OK. It goes to ground when pressed. I am trying to get a used front panel assy. on eBay but that will take a week or more. Just wondered if any of you fellow experts had any other suggestions. I am thinking it could be the motherboard. Is the holding circuit for the power on the MB, on the front panel assy., or in the PS? Anyone know? Thanks all.
  • Wayne Mineard
    Wayne Mineard Sep 06, 2010
    It is not the power supply. It is not the HDD. I redid the thermal heatsink compound. I am going to replace the front panel connector. Funny thing...it has been up longer right now than it hs been for days. The only thing I did was to move the power cord to another outlet. If that turns out to be the problem,,,,GRRRRRRR!
  • Wayne Mineard
    Wayne Mineard Dec 02, 2010
    Just for the record...it was the motherboard.
  • 808 Answers
Syptoms u have identifies are most probably linked to registry errors on ur computer it is wise to run? a registry repair scan with reginout? registry cleaner....
Posted on Sep 01, 2010
'No rgb signal' to second (old) monitor
try restarting the pc in safe mode
uninstall the graphic driver restart the pc and again restart the pc
this is problem of screen resolution
Apr 10, 2014 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Can i install 2x1gb ram with existing ram oo i just swap it out
If you have enough slots, you can add the RAM to the existing amount. RAM does not have to be matched pairs like it used to be a long time ago.
Nov 16, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150, formated main partition, and want factory settings restore
once you put in a different OS there is no factory system to restore . messed up on this one
Jan 30, 2018 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Laptop shut down error
The DDR2 RAM memory has failed and must be replaced.
You can get a new one from here
http://www.edgetechcorp.com/memory/upgrade.asp?cid=28784
Jul 09, 2010 | Dell Latitude D410 Notebook
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Intermittent shut down
That has to do with windows programs. Try doing a system back up if that doesn't work wipe the hard drive and put windows back on it. I have the same system and that has happened to Me. That is what I did. Now it works fine.
May 24, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I need a diagram for the mother board
http://support.dell.com/support/edocs/systems/dim5150/en/om/WD846A02.pdf
Try the above might help.
The board you put in should have a model no ont and rev no.
Cheers
pcfixit
May 06, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Mar 28, 2009 | Dell Dimension 9200 PC Desktop
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
69 people viewed this question
Alun Cox
