Question about Samsung 4 Channel Dvr
On step 3 Connecting SDE-120 to the router. I have pressed the [MENU] Button but nothing appears on my screen.
2 Suggested Answers
SOURCE: i had an SdE-120 and all the screens go in blue ,
Under System Setup and then,, turn off "COVERT".
Posted on Jan 08, 2011
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Aug 18, 2012 | Coby kyros Tablets & eReaders
Have a dlink print server dpr1040 and dlink wireless router how do i print wireless
DPR-1040 information - http://www.dlink.com.au/products/?pid=777
All of this is from the manual located at link above under the resources tab.
Wireless Setup
WPS (Push Button Configuration)
WPS simplifies the process of connecting to a wireless network to a touch of a button. To use WPS you must have a WPS compatible wireless router,if you do not then you will need to manually configure the wireless connection in the web configurator (see Web Configurator below).
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, press the WPS button located on the side of the DPR-1040. The blue LED should start flashing repeatedly.
2. Within 120 seconds, press the WPS button located on the wireless router you will be connecting to. This button may also be located in the router's web configuration pages labeled "Push Button Configuration (PBC)".
3. If successful, a wireless connection will be established between the two devices.
This connection is secure and uses automatically generated encryption keys; you do not need to remember them.
Note: If you experience problems connecting to a device, please try again. If you still experience problems, the device you're connecting to may be incompatible with the DPR-1040. Also, make sure you are connecting to a router or access point (AP).
Web Configurator
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, type the IP address of the DPR-1040 into your browser, the default IP address is 192.168.0.10. If this does not work, use the PS-Link utility to find out the IP address.
2. Upon accessing the web configurator, click Setup > Wireless Setup.
3. On the next screen, enter the wireless network settings as provided by your network administrator.
4. Click Apply Settings, the DPR-1040 will restart and the wireless setup is complete.
Note: If your wireless connection does not work, check that you have entered the correct network settings into the Wireless Setup screen.
May 18, 2012 | D-Link DIR-412 Mobile Broadband Wireless...
How can I connect my blue ray to my wifii connection at home? If you can tell me the steps? Thank you
To connect wirelessly to a wireless network using WPS (Wi-Fi Protected Setup):1.Press ? or ? to select Settings.2.Press ENTER. The Settings menu opens.3.Press ? or ? to select Network. The Network menu opens.4.Press ?, press ? or ? to select Wireless, then press ENTER. A list of network options opens.5 Press ? or ? to select WiFi Protected Setup, then press ENTER. A screen will appear asking you to press the button on your router.6.Press the button on top of your router.7.A screen should appear on your TV that says "Success" when your player is connected to the router.8
Press ENTER to close the message.
Sep 12, 2011 | Insignia NS-BRDVD Blu-Ray Player
I had a pattern password on my Coby, and I havent used it in a long time. Now I need to use it but i forgot the the passcode! Please Help!!!!
You have to reset your tablet back to factory settings: If you have MID7015: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
*******This procedure will delete all items (file's) and entries on the MID7015******
Sep 01, 2011 | Coby Kyros 716829701508 Tablet PC
I keep getting an error message everytime i turn it on and when i try to look at my pictures in my gallery.. it says something like andriod.proces..media isnt working and also it will knock me off the...
You did a soft reset, try master reset: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
Aug 27, 2011 | Coby Kyros 716829701508 Tablet PC
How can i reset my coby tablet
Aug 20, 2011 | Coby Kyros 716829701508 Tablet PC
Forgot my unlock pattern
This does not work. I am getting nothing. Please help
Aug 19, 2011 | Coby Kyros 716829701508 Tablet PC
I have a coby Kyros and I forgot the password and can't get in. how can I take the password off?
Aug 18, 2011 | Coby Kyros 716829701508 Tablet PC
How to unlock it if you forget the password?
This is for MID7015
Jul 07, 2011 | Coby Kyros 716829701508 Tablet PC
Samsung 4 Channel Dvr Logo
1,283 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
