Question about Kohler Plumbing
Kohler Faucet Model R10430-N-CP The diverter (item #758787) went bad on the faucet. Received the part from Kohler, but don't know how to remove part from inside the body assembly kit. I was told by the customer care center to remove the diverter with a pair of needle nosed pliers, but seems to be jammed inside. Am I doing something wrong or am I just supposed to grab this part and pull it out as hard as I can? I also asked the customer care center where the retaining ring #75564 is located, because by the directions I have, the part seems to be just above what I am trying to remove, but I do not see the retaining ring. Thanks.
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
Have Kohler diverter, GP 75878 but no instructions as to how it should be installed. Is it under sink where sprayer hose is attached?
Shut off water supply Under Sink: · Unscrew brass connector for spayer hose · Disconnect single water line to faucet bysqweezing lever on connector and Gently pulloff. · Loosen two screws on faucet base washers thenunscrew the washers on thebrass faucet shaft ( NOTE: Have someone hold the fauct so it does Not accidentlyfall in sink when the support washers are removed) · Take faucet out of sink · Unscrew brass collar at base and remove · Remove Set Screw on lower body of faucet · Pull out Brass Mechanism from faucet · The Diverter is located in the Brass mechanism · Remove the Washer · Pull off the small top valve in center of theDiverter, if still there · Using a large wood screw that fits/screw intothe exposed hole In the center of The plasticdiverter, screw it in and pull out the remaing part of the old diverter · Flush out Faucet to remove any remaining debrie · Replace with new diverter and replace washer · Grease all areas that where greased when mechanismwas removed Remove & clean the faucet Airrater and replace only afterEVERYTHING has been Completed soyou can flush the faucet out again into the sink, then replace.
Dec 20, 2010 | Kohler Model 10430: Fort® Single-control...
I've installed a newly purchased Kohler forte 10433-VS faucet but unable to get spray to fully engaged and seems to leave the partial spout running resulting in a in between or partial spray and spout. Is...
Sounds like the diverter is not working properly. It is located in the spout and it maybe sticking or bad. Go to link below for a installation guide with parts break down. Click on installer's and designer's bar below picture of faucet for a diagram of faucet that may help you out.
http://www.us.kohler.com/onlinecatalog/detail.jsp?from=thumb&frm=&module=Faucet+Collection+Kitchen&item=9559802&prod_num=10433&section=1&category=4&resultPage=0-711729362
May 31, 2010 | Kohler Model 10433: Fort® Single-control...
Kholer faucet won't move from sise to side
under the neck there is a o-ring it is starting to go bad.call a plumber to fix if you can't do it yourself.
Jun 28, 2009 | Kohler Model 10433: Fort® Single-control...
How can be removed the bonet of de Kohler kitchen faucet model K-r10430
try this if you need more help just ask... THX
http://www.us.kohler.com/onlinecatalog/pdf/1011154_2.pdf. The bonnet is screwed on and this should give you what you need. If you have any trouble just ask.
Jun 13, 2009 | Kohler K-15176-PT-7 Coralais...
Faucet issue
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Side sprayer won't spray
THe diverter inside of the faucet is malfuncting. Remove and replace the diverter valve. It is located right under the spout assemble.
Mar 25, 2009 | Kohler K-10416-BN Fort½ Single Control...
Greetings! My Kohler kitchen faucet model K-10416 with sprayer (16 months in use) is making noise when water is turned on in both hot and cold positions. Also, when sprayer is used water flow is not being...
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Jan 20, 2009 | Plumbing
Plumbing Logo
239 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
