Question about Toshiba E-Studio 310c Laser Printer
What is the difference between the toner and developer on this printer? The manuals we have don't give any info on installing developer, but you can purchase both toner and developer for this copier/printer. Help!
Toner provides the color, Developer consists of magnetic particles that carry the color on the outside of the developer drum, which is magnetic. Some developer is lost on each copy, although most stays in the developer unit. When you run low on developer, your image gets lighter and lighter, until the machine reports an error because it can no longer self calibrate. One change of developer suffices for many changes of toner. There is a procedure involving various actions and codes to flush the developer material out and load new developer in. This is not difficult, but there are a couple of reasons you might not want to do it if you are unsure why or if you should. First, developer for these estudio copiers, is very expensive. Second, unless you know how many copies have been made on the existing developer, you might change the developer, and fail to correct the problem. There are related service items, involving the cleaning blades, and seals, servicing charging grids, corona wire, and general cleaning of the 4 developer units and opc drums. Including dusting with zinc sterate, etc., etc. Its hard to know where to begin or where to stop. If you really want to know all about it, order a manual from any of a variety of on-line sources. Good luck
Posted on Nov 04, 2010
Testimonial: "Thank you very much. Now at least we know we need to get a technician. I just hate bringing one in to push one button!"
Sharp AR5516 Printer Error F2 40 Pls Provide Solution
Detail:
ATC sensor value abnormality
Cause:
Connector connection trouble
Toner cartridge installation trouble
Sensor breakdown
Check and remedy:
Connect the connector again.
Install the developing unit again.
Replace the developing unit with a normal one.
Thats what the Manual says, your toner is not replenishing , could be your toner motor , or your toner is empty , or your developer sensor
Feb 24, 2015 | Sharp Office Equipment & Supplies
Sharp MX-181OU-Call for Service. Code: F2-40 How do i fix?
SOURCE:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Sharp&model=MXM363N&code=F2-40
Seems to be a black toner supply issue. Try a different black toner cartridge. Also, make sure the sealing tape has been removed, and give the cartridge a good shake before inserting. Also could be waste toner cartridge, or even the developer, but we always hope for the least expensive option first!
Feb 11, 2015 | Sharp Office Equipment & Supplies
How kyocera laser mfpsenses toner bin and powder
toner and developer are different the developer is usaly by the drum check too see if its in the machine or installed correctly
Jul 27, 2014 | Kyocera FS-1035MFP
Developer unit not installed
yocera ecosys fs-1124mfp toner container 0r the developer unit is not install
Apr 09, 2012 | Kyocera Office Equipment & Supplies
I NEED TO DUE A 600K MAINTENACE KIT BUT KIT CAME WITH NO INSTRUCTIONS. TRYING TO DETERMINE HOW TO CHANGE THE DEVELOPER PROVIDED IN KIT. ANY INFO OR HELP WUD BE GREAT
Disclaimer ... this advice is worth what you paid for it ... Nothing...
DO NOT FORGET TO TAKE THE NUMBERS OFF THE NEW DEVELOPERS FOR THE SENSOR RESETS EACH DEVELOPER HAS A GREEN TAG WITH A BAR CODE AT THE BOTTOM !! VERY IMPORTANT !!
Writing this from memory... may have forgotten somethings...However make sure you have a shop vac in case of accidental spill. Ive done this SEVERAL times... don't actually enjoy this job of many other options....Lexmark X945 ... oh power off the printer first ...
1.Remove the front door 2 screw hold the bracket at the bottom. After the screws are removed they should slide and lift off. The 2 straps disconnect at the printer. Squeeze the tabs and twist they should pop off but be careful not to brake them.
2.Remove the small front/left cover and toner fill shroud. 2 screws hold the front/left cover in place and it just slides up. The toner fill shroud has 4 screws that hold it in place.
3.Remove the toner fill assemblies each color has 1 screw. Be sure to pull the closing slip on the bottom of the drain where it connects to the developer to avoid spilling more than you must.
4.Remove the waist toner full housing assembly. If I remember correct its 1 screw and 1 C-Clamp. Detach the cables and put the part to the side.
5.Remove the bracket that holds the developers in place being careful not to drop cable snaps.
6.Remove old developers fill new developers with fill kit and NOT toner.Make sure the developers are properly insearted so when you get it back together you don't have to take it apart again. Good way to check it when you put them in push down on the end of the developer that sticks out. If it lifts in the rear you don't have it in correctly.
7.Reassembly(reverse what you just did) and reset sensor settings in configuration menu mode.
Apr 18, 2011 | Lexmark X945E Printer
Blank copies on an ar208s sharp copier
Inside this machine has 3 sections. Toner cartridge, developing unit and drum unit. First pull out the toner cartridge then you will see a blue anodized screw, loosen this screw then pull this section ( developing unit ), if there's already toner inside the chamber, clean it and pour the all the developer into the chamber then put back the developing section, tighten the blue screw and install the toner cartridge.
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
First Installation
they are on the way plz dont forget to rate you expierience on fixya.com PLEASE LET ME KNOW IF NOT RECIEVED one was 20MB so it will take some time
May 01, 2009 | Ricoh Aficio MP1600SPF Copier
My copier Minolta EP2030
does not follow to do the repeated installation of developer. If you doing the installation, they will be different from factory. Minolta itself is determined concentration of the toner and after a certain time will stop the miks. Simply backfilling new portion developer and set the bank up with toner. Include the device. He stops in a certain time itself.Good luck.
Nov 24, 2008 | Office Equipment & Supplies
Ricoh Toner for FT3313 and FT3713
When the developer is the same the toner is the same.The toner drops in to the developer,thus the toner must be the same.They just package it different to be a pain!
Nov 20, 2008 | Ricoh FT3713 Copier
Installing developer
If you give me more details regarding the exact model, I may be able to link you to a service manual.
Jan 23, 2008 | Office Equipment & Supplies
Toshiba E-Studio 310c Laser Printer Logo
2,780 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
