Question about Refrigerators
How to replace water inlet tube running into bottom of fridge on fridge side from water valve.
    Genius:
  • 1,073 Answers
Get a plastic barb connector at lowes, or eq. inside the fridge side connect the end of the old tubing to the new tubing with the barb connector and pull the old line out from the back of the ref untill the new line comes out the rear of the machine to the water valve and reconnect tubing inside fridge
Posted on May 09, 2008
How do I change the plastic tubing that runs from the ice and water dispenser to the water inlet valve on a KitchenAid refrigerator Model #KSRG25FKWH03
Here is a video that may help you. YouTube also has quite a few other videos that pertain to this problem also. Give them a look.
Oct 15, 2012 | Refrigerators
GE GDS18LBP water inlet value - is it bad ?
look in the freezer and make you the fill tube in not froze up if it is you have a valve that is dripping and then it freezes up the tube. if that is what you have you will need a new valve.
Jun 07, 2017 | GE GDS18LBP Bottom Freezer Refrigerator
KSSC48QMS01 water drips from the feed tube for the ice maker in the freezer compartment how do you access the water valve under the fridge?
Hi carey_ritche,
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
Before testing the water inlet valve, unplug the refrigerator to avoid an electrical shock hazard.
-->The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
-->Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
-->Test the water inlet valve for continuity using a multitester. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Hope it helps.
Thank you for using FixYa.
May 07, 2011 | KitchenAid KSSC42FMS Side by Side...
Wont make ice and frozen water running down door
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice maker won't work
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
My frigidarie refrigerator ice maker does't work
Jun 06, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
How do you get the ice maker to make ice consistently
Jun 06, 2010 | LG LSC27931S Side by Side Refrigerator
The water dispenser unit has a tube coming into the back of the fridge. Anytime you dispense water, it will also leak from this tube in the back. Also, about once a day or so, it will sound like water is...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. You can thaw the fill tube and replace the water inlet valve.
Sep 27, 2009 | Jenn-Air JFC2087HRS Side by Side...
The icemaker overfills and the water keeps running and runs out of the fridge onto the floor
Hi, If the ice maker is overflowing, you will need to change the inlet valve. The inlet valve should only draw water when 120V is sent to the solenoid to open it. The inlet valve is located in back and has the water supply tube attached to it.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 05, 2009 | Amana ASB 2623 Side by Side Refrigerator
Ice maker whirlpool fridge
FIRST MAKE SURE IT'S ON,,THEN YOU NEED TO SEE IF YOU HAVE WATER TO THE WATER DISPENSER,IF YES CHECK THE TUBE GOING TO THE ICEMAKER,PULL TUBE OUT LOOK INSIDE TO SEE IF FROZEN LOOK TO SEE IF THE WALL WHERE TUBE GOES IN IS FROZEN,IF NO TO BOTH YOU HAVE A BAD INLET WATER VALVE,TURN WATER SUPPLY OFF,REMOVE PLASTIC TUBING FOR ICE MAKER AND DOOR WATERGOING TO WATER INLET VALVE,GET THE PART NUMBER AND GO TO YOUR LOCAL APPLIANCE PARTS STORE AND GET THE NEW PART,REPLACE TURN ON WATER AND ALL SHOULD BE GOOD,HOPE THIS HELP,THE WATER VALVE IS ON THE LOWER BACK SIDE OF FRIG.
Jun 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
