Question about HP OfficeJet Pro K8600 Printer
The cradle is stuck to the right side of the printer. How do I loosen it?
    Scholar:
  • 107 Answers
Well, if the cradle is stuck due to cleaning station not working, then you will need to back off motor to unlock and move cradle, problem is this is a worm gear drive, and really small movements when turning motor, this will require taking covers off of machine as well as possible removing carraige assembly. since the screw that holds the cleaning station in, is under carraige unit. might want to think about taking machine apart first, having enough desk space and patience.
Posted on Sep 01, 2010
I have a HP Photsmart 8250 it is telling me that the printer cartridge cradle is stuck. I have taken all cartridgese out and in again. I have opened the back and there doesn't seem to be a paper jam. I...
on the printer if the cradle is stuck on right position disconnect the plug from the outlet then push gently the cradle to the left then plug the unit turn on if it is stuck on left disconnect the plug from the outlet then push gently the cradle to the right, hope it helps god bless
Jul 31, 2011 | HP Photosmart 8250 InkJet Printer
Cartridge cradle is stuck
Hi KHphoto, you can see this steps to fix your printer jam,
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
original post*
If you are still having problems let me know.
Jan 03, 2008 | HP PhotoSmart 7550 InkJet Printer
Ink cartridge stuck on left side in cradle and will not release
Take the cradle out of the printer, using a flat blade screwdriver prise up on the left corner of the toner cartridge and pull toner cartridge from the right hand side.
the problem is cause when the toner cartridge in install incorrectly, inserting at an angle to the leftside first and so the toner trap door does not rotate.
The correct way, is to place the cartidge on the cradle and press from the centre down on the toner body.
May 27, 2009 | Kyocera FS-2000D Laser Printer
Fast blinking red light, message says cartirdge service station is stuck
Solution
Follow these instructions to adjust the clutch on the printer.
Print a test page.
NOTE: If the printer continues to display a Print cartridge cradle is stuck message or make grinding noises, click "contact hp" on this page for more support options.
May 26, 2009 | HP PhotoSmart 7660 InkJet Printer
Carriage cradle stuck on right side!
Carriage system is broken. Uneconomical to repair. Sorry
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
The cradle is stuck
Fixed it myself...found this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00738923&dlc=en&product=443024
It would print the Tap Test as instructed in this illustration....but then wouldn't move to print anything else. So redid the Tap Test several times....then I lifted the lid while printing a test page so the cartridge was in the center and I could get ahold of it to slide it....left the printer ON, but unplugged the power cable...and then I was able to move the cartridge back and forth. I then took QTips with Windex on them and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
A couple more test prints...and sliding the cartridge......and it is finally running again.
Jul 06, 2008 | HP Photosmart 8250 InkJet Printer
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help
There seems to be a problem with the cradle not "lifting" itself up and over what appears to be some sort of guide. Rock the cradle gently back by hand (it will only move a few millimeters) and move it all the way to the right into its bay. Cycle the printer power and it should be fine.
Mar 03, 2008 | HP PhotoSmart 7260 InkJet Printer
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
Cartridge cradle stuck
Hey chips 53 Very simple, Go to the market and purchase a set of screw driver of long sleek neck (for star screw). and open the four screw present four different side in the printer. After open the screw, open that door, from where you insert the cartridge. insert your hand into the printer and lift the portion upside. Remember you have to lift equally (but slowly-slowly) if you see that the upper body is separating, you have to concentrate to lift the portion from right side because wires has been attached left side. After removing the upper portion you can easily move the carriage. And do what you want
Sep 12, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP OfficeJet Pro K8600 Printer Logo
171 people viewed this question
Seeker5211
Seeker5211
