posted by andie6294 on May 08, 2008
I have the above mentioned vacuum. Suction is fine through the hose, but when the hose is connected to the base, there is barely any suction at all and it won't vacuum. I cleaned out as far as I could reach, but it still isn't working. Any suggestions?
Solution #1
posted on Jun 15, 2008
I had a similar problem with mine. When you take the collector container out, if you reach your hand up, you will fill a round, plastic piece. Gently turn it and the piece pulls out. On the outside of the piece is a foam filter that may be plugged. There is another filter underneath the collection container in a pull-out drawer. Both filters can be washed with cool water, allowed to dry totally, then replaced. I understand that both of these filters need to be washed "frequently". It worked for me, hope it works for you.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bissell 37604 Lift-Off Pet Bagless
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Repair Service
Find Vacuum Repairman Near You:
