Question about HP Photosmart C3150 Printer
Color ink is not working
Hi, I have a photosmart C3150 printer and the color ink isn't working and when I print something out it comes out pink and then fades at the end of the printing. The ink number is 93. If you can help me that will be great. Thank You!
  • estellej Dec 05, 2008
    Our printer only prints yellow and green on the self test and not at all from the computer
  • Mark Gough Feb 12, 2009
    Have the same problem, worse yet is when I installed new cartridge printer won't work. Never had this problem with any hp printer I've either owned or worked on before.
    President:
  • 415 Answers
If it is still under warranty either call hp or if you have the receipt take it back to where you bought it from.
Posted on Mar 06, 2009
Hp photosmart c3150 keeps color light and check cartridge light keeps bliking after replacing with a new one.
It sounds like you ink cartridge is electrically bad; you can run the diagnostic 'tap 41' test to confirm. The HP 31xx printer 'access procedure' will be very similar to this HP Fxxx series access procedure:
http://www.youtube.com/watch?v=m-OM09NvNqg
Good luck:
inkjet411.com
Feb 19, 2013 | HP Photosmart C3150 Printer
HP C3150 is printing green instead of yellow. How do i get yellow?
You should first check your ink levels to make sure you have enough of all colors. Do this through the printer toolbox on your pc. If the ink levels are fine you should print out a diagnostic page. Follow these steps to print out a test page: 1. Press and hold the cancel button 2.Press the start copy color button. 3. Release both buttons.
If there were problems with the test page run the clean print cartridges utility. This can be found in the printer toolbox in the device services tab.
If that fails as well, you should look at replacing your ink cartridges with new ones.
Apr 22, 2011 | HP Photosmart C3150 Printer
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Feb 03, 2011 | Office Equipment & Supplies
My C3150 is not printing in color and I am pretty sure that the settings are correct.
You need to calibrate the printer. You are not supposed to skip this process. After loading a new printer you need to do the calibration without fail. You could get the black ink into work back. For this you need to run 'Self Test Diagnostic'. Along with this you need to also run the 'Print Cartridge Alignment'. This would help you to get the black ink to work.
Nov 16, 2010 | HP Photosmart C3150 Printer
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Black and white printing not working
sounds like its a expired ink issue. on alot of the hp photosmart printers the ink has a expirey date on the carts the best solution would be to contact hp and chances are they will send you free carts if your ink has been expired. when a black ink is almost out most of the time it trys to draw ink from the color carts mixing to make the appropriate color.
but you can also try the following.
See the instructions for
calibrating a print cartridge in
the Care and Maintenance
section of the HP Photosmart
Printer Help.
Aug 11, 2008 | HP PhotoSmart 7960 InkJet Printer
HP C3150 error flashing....not printing!
You may have got a bad ink cartridge, I would try changing it again to see if that helps!!
Jun 19, 2008 | HP Photosmart C3150 Printer
Dear Black Rose
It is strongly recommended to change your colour cartridge.
Or it can be possible that you did not use your colour cartridge for a long time.
The nozzle of colour cartridge are blocked, if you did not use your colour cartridge for a long time.
Purchase a new cartridge if you can or go for a local refiller to refill (if possible) your colour cartridge.
Thanks
May 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
It could be a bad color cartridge.
May 07, 2008 | HP Photosmart C3150 Printer
HP Photosmart C3150 Printer Logo
154 people viewed this question
Seeker5211
Seeker5211
