Question about Sony KV-32S35 32" TV
KV-32V35 32 inch sony? I an only seeing snow and noise on the screen. When I auto channel, it will not pick up anything. Plugged in another TV and it works fine. Also, when I change channels, it keeps flipping to the same channel. If it is on 3 it stays on channel 3.
techman
  • 3130 Answers
SOURCE: channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Posted on Mar 25, 2006
rockitman187
  • 2559 Answers
SOURCE: cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Posted on Feb 01, 2009
SOURCE: my television screen size keeps changing when on
rolled it off a cliff.
Posted on May 29, 2009
welcomejee
  • 10594 Answers
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Posted on Jun 09, 2009
cactus bob
  • 267 Answers
SOURCE: Sony KV-32s40 (picture flashes in and out)
YOUR CRT (PICTURE TUBE ) IS GOING BAD . this is the most common way a sony tv crt fails . the tv is to old to make it worth a crt . but if your handy and carefull there is a way to get a little more time out of it . start with the tv cold , remove the back and look on the little board connected to the neck of the crt . there is a control marked "SCREEN " plug in the tv and cable and start it , with it flashing adjust that control , one way will make it flash more and one way less , adjust this no more than you need to , just enough to stop the flashing .NO MORE ! just be carefull the voltages in a tv can KILL . dont touch anything else in there and use a little inslated screwdriver to make the adjustment good luck .... if this answer helped please leave me 4 stars rateing , this high rateing will keep me in the paid answer department , thank you
Posted on Jun 21, 2009
MY SONY TV KV-27V65 HAS LINES LOOKS LIKE NOISE ALL VIDEO FUNCTIONS
Hello
Are the lines across the entire screen, at about an inch apart to each other? Are they thin whit lines acorss the screen; so many of them?
Mar 02, 2012 | Sony KV-27V65 27" TV
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
I did a reset on my Sony WEGA TV but now it's not connect with the cable box. Just says no signal. Screen is all snow and no sound other than static.
you need to reprogram channels. Itll only pick up 3 if you are still using coaxial cable from box, or change input to DVI/HDMI, aux, etc.
Oct 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Nov 28, 2009 | Televison & Video
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at tbiasi@hotmail.com. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
SONY KV32V16...can't get all my cable stations.
I called our cable company about getting a converter box and it ended up I didn't need one after all. The cable rep told me to go to the menu and try the auto-programming. He was familiar with the TV I have and said that a converter box is not necessary. So, I tried the auto-programming and still didn't get all the channels...then I noticed on the menu for the channel set up there was the word "Cable" and after it it said "Off" so, I switched that to "On" and did the auto-programming, and Presto! I got all my channels.
Dec 25, 2008 | Sony KV-32V16 TV
Sony KV-21X4U
did you see anything on screen at all event the sound.
Dec 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Snow screen
Your symptom is not a normal failure symptom. Can you be more specific? Is this on all inputs?
Oct 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32S35 32" TV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
