Question about Sharp AR-M237 Digital Copier
Sharp AR-M237 Reset Codes
I get a "maintenance required" error on my display. How do I clear it?
  • yippyskippy Jun 04, 2008
    I changed the toner in my machine and if worked fine for 1 day. I am getting a F2-02 error. The service company changed the drum and it did not clear the error.
  • Sharp Expert
  • 1,326 Answers
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
Posted on May 09, 2008
F2-02with sharp ar-275
Toner supply abnormality
check toner motor and DV mag sensor
Jun 14, 2014 | Sharp AR-M237 Copier
How can solve this error U2-40 to sharp AR 235
Hi
U2-40 = Chip comunication CRUM Error
is reset so ... enter
# Interrupt Clear Interrupt 16 Start
or
you change the toner chip.
Apr 30, 2012 | Sharp AR-M237 Copier
SHARP AR-M237 H2-00 ERROR CODE---HAVE INSTALLED NEW FUSER UNIT WITH SAME ERROR/CODE PROBLEM.
check harness and connector betwen thermistor and control PWB.
clear the error code by using SIM 14 if all didn't work you may have defective AC power supply
I hope this help
Feb 10, 2011 | Sharp AR-M237 Digital Copier
Maintenance error reset
this kind of problem requires maintenance of the machine completely. change the catridge and insert new toner in it. further check for the master code on the manual to reset the machine.
Feb 07, 2011 | Sharp AR-M237 Digital Copier
How do i clear the maint indicator on a sharp ar m 257
PRESS [#] [INTERUPT] [C] [INTERUPT] [20] [START]
Jun 08, 2009 | Sharp AR-M237 Copier
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
May 08, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-M237 Digital Copier Logo
1,321 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
