Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
On clean channel when 'channel volume' is adjusted, the sound cuts out, goes completely dead. I have to switch to another channel and back again or switch off and back on. The amp seems to get confused!
  • Line 6 Master
  • 5,603 Answers
When it is working, wiggle the channel volume control WITHOUT rotating. If the sound cuts out, likely the soldering of the pot leads is broken where it attaches to the board. Try resoldering the connections.
SOMETIMES the control is damaged in which case it must be replaced.
Posted on Sep 01, 2010
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
Whenever I slightly adjust the "Channel Volume"
You've got a loose wire! What's happening is that there's a bad potentiometer (the electrical component behind the knob) that's out of place and is only connecting fully at one point in the knobs circuit (the part where you get full volume) take it in to an amp tech at your local music store and they'll fix it up easily.
Feb 20, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
I have a Fender 2x12 Hot Rod Deville. The clean channel seems to be working fine but the overdrive channel is not. I have to turn it up all the way in oder to get just a little bit of sound. So that...
For the Drive channel you need to use the Drive control AND the MASTER volume control. When the Drive channel is active, the Channel Indicator lamp should be RED indicating the Drive Channel is active. The Drive control knob is used to adjust the preamp volume and distortion level of the Drive Channel. This gives you a clue as to what to check if adjusting the controls doesn't work -- the preamp tubes. Having said that, ONLY try to check these tubes with the amp OFF! Never stick your hand up into the chassis of a live amp. It could be lethal. Your preamp tubes are the ones farthest from where the power cord enters the chassis. They have a rubber like stabilizer on them. They have a tendency to wiggle loose, which is part of the reason for the stabilizer. Again, if you're not familiar with the insides...stay out and get an amp tech to help you.
The Normal Channel only uses the Volume Control to adjust volume.
Feb 01, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My 410 deville's channel switching doent work and is stuck on the clean channel. This really isn't a problem as I always use the clean channel and I only mention this in the event it helps diagnose the...
You may have a switch that may be bad. For the sound level high and low may need new tubes or possibly may not be seated fully into position. These tubes due get quite hot and do get loose over a period of time.Hope this helps.
Nov 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud...
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Sep 15, 2010 | Crate Music
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Behringer UB1222FX Pro: Problem With Left Channel Cutting Out
Try cleaning al of the sliders using an electronics cleaning spray. Choose one that contains a lubricant as well. Dirty sliders can cause this especially at low volume levels. If that does not resolve the provblem, update this and we'll look further.
Dan
Apr 09, 2009 | Behringer Music
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
134 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
