Question about LG Computers & Internet
My entire monitor screen is UPSIDE DOWN...I have tried all of the buttons on the monitor - with no luck. Short of standing on my head, I don't have a clue what caused this or how to reverse action. Can you help / by the way I am currently using another lap top.
  • LG Master
  • 11,800 Answers
This is done by a setting in the advanced display properties - nVidia Control Panel or Catalyst, depending on your video card. It will be labeled Rotate display in nVidia or something similar in Catalyst.
Posted on Aug 30, 2010
    President:
  • 2,571 Answers
You need to go into your display settings in control panel, there will be an invert setting to turn your picture the right wat around, this will be different depending on your graphics card/chipset
The image is upside down and I can't find any setting that could allow me to flip it
You can normalise the screen by a keyboard short cut. Just press Ctrl+Alt+ (arrow key) to flip the window to normal settings.
Thank you for choosing Fixya.com
Sep 15, 2010 | Computers & Internet
The picture on screen is upside down
Jay there should be a External Switch on the Screen,Try looking ttech
Jul 25, 2007 | Legacy LSWR844 8.4 in. Car Monitor
Image is up side down
Hi!
Basically it sounds like the screen has been configured to flip the display along the horizontal axis. The purpose for this is usually for hanging a screen from a roof or stand etc. where it would be technically upside-down.
Check the settings on your monitor. Usually there is a Menu button you can press..what you're looking for is "Display Options" or perhaps even "Advanced Settings". Look at these options & see if anything jumps out at you..hopefully it'll be obvious.
Is it upside down even when you first boot the computer up? Or just when actually log in to Windows?
I'd need to know the make/model of your monitor to give you specific instructions but I've seen this once before when I worked at a hospital (a mental patient had messed with a doctors computer which I found quite funny at the time)...
Hope this helps :)
Nov 21, 2009 | HP Computers & Internet
My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
Mar 22, 2009 | Dell E193FP 19" LCD Monitor
Hyundai flat screen monitor upside down display help?
There are 4 screws on the back that connect the monitor to the stand. Remove them and turn the monitor right side up and replace the screws tightly. OR you can change your layout in your video card settings.
Nov 20, 2008 | Hyundai L91A 19" LCD Monitor
Acer monitor AL1916W question
Stand on your head ??? put the stand on the other end ??
Jus kidding ? Is it a monitor that offers a rotate screen feature ??
Did you buy it used ? almost sounds like the screen is in upside down which is possible but a bit tricky to do.
Sep 25, 2008 | Acer AL1916W 19" LCD Monitor
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
Display is completely upside down
Try connecting it to a different computer. If it's upside-down on another computer, then the panel is probably mounted upside-down. If it can be removed from the stand, remove it and see if it can be mounted the other way.
If it's correct on another computer, then your graphics settings are incorrect. Assuming you're running Windows, go to Display Properties, Settings tab, click Advanced button, look for a tab describing your video adapter (usually ATI or NVIDIA). In the video adapter's setup there is usually a Rotation option. The rotation option may be set to 180-degrees instead of Normal or 0-degrees.
Apr 05, 2008 | Computers & Internet
Monitor displays everything upside down
There are two options:
Stand on your head, or..
Someone may have messed with the monitor settings.
Right click anywhere on your desktop, then choose "properties".
Then click "settings"
Then click "advanced"
If you're using any 3rd party video card (asus, nvidia, ati, etc), you will see an extra menu like this:
Jan 19, 2008 | E-Machines eMachines W2686 PC Desktop
Computers & Internet Logo
409 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
