Question about Canon MX700 Office All-In-One InkJet Printer
The paper feed is screwed up. We tried printing on paper that had already been fed through the printer and a piece got stuck. We think we got that all out but can't be sure b/c we don't know how to fully open the printer and see. Now every piece gets jammed before anything is even printed on it.
    President:
  • 1,335 Answers
The chances are you have a piece of paper blocking the paper path.
Try tipping the printer with the paper input upside down to see if your can dislodge the offending piece of paper.
Next, try taking a thick piece of paper (double weight or construction paper) and feeding it through to see if you can push the offending piece of paper out.
If these do not clear the problem, let me know and we can look at partially disassembling the printer to clear the path.
Please rate this solution. Thanks.
Posted on Aug 30, 2010
Hp Deskjet F4480 continually reads out of paper even though its not and will not print. This problem occured only after I refilled the cartridges and put them back in.
Ok, I had this problem too and it started after I replaced the ink cartrtidges. The printer had a flashing light and the software read "out of paper". I can't be exactly sure what fixed it but here's what I did: I unplugged the printer while it was still on and left it unplugged for several hours (several minutes should have the same effect of clearing the device's memory, I just had to go to a meeting). I then plugged it back in and the printer fed the paper, but was feeding it sideways. I removed that paper and put a single piece of 4x6 photo paper in it and it fed that paper sideways also, crinkling it up. I tried a few more times by hitting the 'Cancel' button which would cause it to try to refeed the paper. I then checked the back of the printer and discovered the back panel had come loose at some point. I replaced it and the printer then fed a sheet correctly and printed the alignment page. I think the thing that fixed the issue was leaving the machine unplugged for awhile.
Feb 07, 2010 | HP Office Equipment & Supplies
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
I am trying to print but nothing is showing up on the page
YOU MIGHT TRY CLEANING THE PAPER FEED ROLLER WITH ISOPROPHYL ALCAHOL, THE ROLLER IS ABOVE WHEN THE PAPER TRAY IS REMOVED
Dec 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Paper jam R240
A qualified - manufacturer certified servicer is needed here. Your are correct, the missing piece is still inside and also, yanking-out a paper (while it is being fed by the printer) will have a definite damage on the paper-feeding mechanism.
In-warranty or not - u need to call the manufacturer.
Jun 13, 2008 | Epson Stylus Photo R2400 InkJet Printer
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson 3810
look in and around where the paper is fed into.there maybe a small piece of paper stuck somewhere inside. if you do see something, unplug the machine and try to pull it out with a pair of needle nose pliers. if you do get the obstruction out, try feeding the paper back in and see if it now works.
good luck.
wg
Feb 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Paper feed
Something is stuck in between the
tray and rollers possibly torn paper
in one of the corners
try with just a few sheets of paper
Once you remove the jam
wilthout breaking any plastic
parts it will work okay
Nov 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
91 people viewed this question
old marine
old marine
