Question about Sharp AR-M237 Digital Copier
Reset Code I need to reset a "Maintenance Required" error on the display on Sharp AR-M237.
  • Sharp Expert
  • 1,326 Answers
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
Posted on May 15, 2008
Maintenance error reset
this kind of problem requires maintenance of the machine completely. change the catridge and insert new toner in it. further check for the master code on the manual to reset the machine.
Feb 07, 2011 | Sharp AR-M237 Digital Copier
How to problem sharp AR-M237 erroe code H4-01
you have problem with the fuser temprature maybe the the heater lam or may be thermal fuse just check bothe if ok just reset.
thanks
May 22, 2010 | Sharp AR-M237 Digital Copier
Please i need to reset my sharp ar-m236 password how do i do that
You can reset the nic card password by ressetting the nic card to factory defaults, custom setting, key operator, 00000 , print settings , network settings, reset the nic, default password is Sharp
Mar 15, 2010 | Sharp AR-M237 Copier
Problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Jun 04, 2009 | Sharp AR-M237 Copier
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
May 22, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
May 08, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-M237 Digital Copier Logo
671 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
