Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
My IM65 light flashes green then red, fan seems to be working and the gun does fire
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
I have a new im65a pasloade nail gun that has only fired a couple of hundred nails and after standing for about 16 months the gun does not seem to be firing the fan comes on the green light flash the
your gas has expired , look at bottom of canister check the date. buy new gas also make sure cap on gas canister is down all the way till it snapps new gas doesnt come with cap down all the way
Apr 24, 2012 | Senco Air Tools & Compressors
Paslode im350/90ct green light goes red when applied to surface and wont fire
Unplug. Check that you don't have a nail jammed in the end of it.
Apr 03, 2012 | RTO Air Tools & Compressors
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Gun was jamming up so i cleaned it now green light flashes but if i disconect wire put battery in then plug wires back in fan runs then stops and green light flashes again what could it be
the green light flashing means the tool is ready to fire. when the trigger switch is depressed or the safety activated the fan will run for a short time and automatically shut off. if the tool is not firing then it could be a loose connection of the circuit board or the spark unit. Let me know what the exact problem is and I will try and help further. Also check the expiration date on the bottom of the fuel cell.
Apr 16, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My paslode keeps flashing green red after it fires once. I have checked the wiring and all seems fine. The trigger and contact switch are both working but when it sparks once it cuts out
is the fan working? if you have the tool partially disassembled and it seems that you know what you are doing you can fire the tool in this position to check for the entire function. When was the last time cleaned? To fire and test motor connect the head assembly back up laying to side so fan can turn freely then push trigger fan should come on and run for a matter of seconds, next depresss the safety switch and then trigger to get gun to fire, look at spark for crisp action, fan should be on and again run for a few. If not then you have a problem with either fan or spark unit. You can go to Paslode.com and type in your model and they have a troubleshooting guide in the manual that might help.
Sep 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 1st fix gun .battery fully charged and placed into gun.the light flashes green and the gun will fire once after which the light flashes red and the gun will not fire.any ideas.i have tryed other...
I would look at the fuel cell on the bottom is a expiration date and they will not fire older fuel. Also do you remove the battery and it does the same thing? When you depress the safety on the work can you hear the fan motor? You say the tool is clean does it have enough lube to move all items freely. Just a couple thoughts, Also look at the spark plug wire for being broke or coming out of the spark unit. Let me know and we will go into this deeper.
Jun 30, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
802 people viewed this question
Top RTO Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
