Question about Sanyo Heating & Cooling
When I turn on my Sanyo KMS0712 (bought in approximately 2003) after about half an hour a large amount of condensation begins to drip from it and will not stop (even after it is turned off) for about another half hour. Is there any solution for this I can try at home without calling a repair technician? The unit has been working well all summer. Thank you!
  • Sanyo Master
  • 43,501 Answers
The unit has probably developed a refrigeration leak and has iced up...the leak will need to be fixed and the system recharged...
heatman101
Posted on Aug 31, 2010
Kms0712. Why is it dripping?
All air conditioners condensate thats how it removes humidity. Make sure your drain line isnt stopped up or ran at an up huill angle.
Jun 26, 2015 | Sanyo Heating & Cooling
How to do you fix a sanyo 46 lcd HDTV with a half screen distortion?
Shouldn't have bought a Sanyo. It's not the same company it once was. It's toast.
Mar 31, 2015 | Sanyo Televison & Video
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Nov 20, 2014 | Keurig B40 Coffee Maker
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
Water leaks from under the middle but not all the time maybe once or twice per month
condensation normally drains thru a tube at the bottom of the frig to a drip pan under the condenser coil (under the frig) .. the water normally just evaporates from the pan .. if there is too much moisture in the frig, that usually means a door is ajar (not closing completely) or the seal on the door is not sealing properly .. warm moist air from the room getting in will cause too much condensation .. the drip pan may overflow ... you should check the drip pan for damage (clean the condenser while you are down there) .. also check the tube that carries the condensation (back bottom of the frig) .. it has a one way valve (lets water out only) that becomes stuck sometimes and needs cleaning.. if there is a large amount of moist things in the frig then that an cause the problem as well .. just put those things in plastic bags or containers to eliminate that problem ..
Nov 21, 2009 | Amana AFD2535DES French Door Refrigerator
1999 Jeep Wrangler 4 cylinder (manual tran). I noticed a large pool of water in the floorboard on the passenger side of my Jeep. This was after driving for about an hour with the a/c on in Texas at about...
My dad has a 2004 Dodge Dakota with the exact same problem, the passengers side floor board is soaked with water after running the AC. Also there is a pool of water that collects under the truck.
We are getting a mechanic to look at it, I will post what the problem is when we find out.
Jun 25, 2009 | 1999 Jeep Wrangler
Condensation from the coils
check drain hose maybe is obstruct or have bad plunk.
Feb 12, 2009 | Sanyo 09KS51 Mini Split Air Conditioner
Water puddling under the frigerator
I had the same problem. The problem was the drain tube from inside the freezer to the drain pan was partially plugged so ice was building up inside, then when the freezer went thru its defrost cycle large amounts of ice were melting. I fixed it by removing valve in the end of the drain hose, all ice inside freezer and ice in drain hose (pour hot tap water thru it).
Hopefully this helps.
Jan 22, 2009 | Refrigerators
G.E. 20.3 CU FT UPRIGHT FREEZER
Check condenser fan to see if it's working. It's the fan next to compressor
Nov 20, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
Heating & Cooling Logo
98 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
