Question about Coleman 2 Burner Propane Stove 5430E700
I've lost my R430-565T Regulator Assy & I'd like to order a new one. Thnx Dave.
2002 honda van window off track
Not off track
That is like saying your back went out
There is nowhere for it to go
You remove the inner door panel
Inside you will see a broken window
regulator or cable
You remove it & the motor, as an assy &
switch the motor to new part ,you get from a
dealers parts dept
Dec 01, 2012 | Cars & Trucks
Can i replace broken cable on a power window
Can you?
I do not know,have you ever removed a door panel
& worked on a window regulator?
You can get the broken regulator cable assy at a
dealer & possibly order from auto parts store also
Just wear long sleeves & thin gloves when you can
Lots of sharp edges there, so keep the band aids next
to the job.
Sep 29, 2012 | Cars & Trucks
I have a 1986 Cadillac Fleetwood with two front window motors that have stopped working, and a rear passenger side window that will only go down. I am trying to replace the driver window now and have...
I had an 86 Deville
You have to drill out the rivets
-- to remove the window regulator & motor assy
If the motor is bad (test it-put battery
12v to it) then you drill out the smaller
rivets to remove the motor & keep the
window regulator if good.
If the regulator is bad, remove the good motor
& put it in the new regulator
The regulator can be bolted back in as you
will not have a big size pop rivet tool for that,
Before you remove the rivets, check the height of the
window glass above the door,when window is down
You can set it just above the molding per build or down
even by adjusting how you bolt the regulator in
The regulators wear out & cause a sloppy window movement
& the plastic on top can not be fixed
nor can you afford one.
Jun 23, 2011 | Cadillac Fleetwood Cars & Trucks
How can i replace the reverse light of a 2006 bettle? There is no room or place underneath or in the trunk. Help me please. Thnx
Inside the trunk you will find large plastic screws to remove the complete tail light assy. Once you have the assy. out of its pocket you will find access to the bulbs, which have a base that turn 1/4 turn to pull out.
Mar 13, 2011 | 2006 Volkswagen New Beetle
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
Need a window motor regulator assy for 94 Buick Century SP 6cyl
You could just get them from a bone yard. And I believe those particular motors are universal.
Jun 06, 2009 | Buick Century Cars & Trucks
Coleman 2 Burner Propane Stove 5430E700 Logo
203 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
