Question about Konica Minolta bizhub C450P Laser Printer
The Ozone Filter is full. Where is the Ozone Filter located on a Bizhub C451? Should I buy a new filter or just clean it out with an air cannister?
5 Suggested Answers
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
  • 15 Answers
SOURCE: Replacing Image Transfer Roller Unit & Paper Dust/Ozone Remover
hi this unit located in the RIGHT DOOR
Posted on Jan 15, 2010
xeerie
  • 347 Answers
SOURCE: I need to replace the Ozone Filter on our BizHub
go into service mode. Press the Utility/Counter button on your operation panel, select meter count, then detail, press stop,0,0,stop,0,1. This will put you in service mode. Find and press "COUNTER" button, Locate "LIFE COUNTERS", and clear OZONE filter. Always remember it, have a good time.......
Posted on Jun 21, 2010
I replaced the Ozone Filter, now how to I reset the the machine?
go to service mode, counters life and clear the ozone one
Oct 28, 2015 | Konica Minolta Bizhub C451...
How do I change the filters in my Bizhub C360?
what sort of filter is it. ozone filter then see this video for possible location it is a different model but it might be a similar setup on your machine. http://www.youtube.com/watch?v=ZQtatt-6gTM
If it is the dust filters on the toner cartridges then
http://www.youtube.com/watch?v=cNOlf43vdRE
Oct 27, 2014 | Konica Minolta Bizhub C360
Fuser unit
can you explain more the functions of each are as followed fuser melts the toner to the paper so it dosnt rub off ozone filter filters out the ozone so you don't get headaches and turn al the rollers to bubble gum transfer roller pushes the paper onto the transfer belt applying the image to the paper and imagine unit is where thetransfer belt gets the image from
Aug 16, 2014 | Konica Minolta bizhub Office Equipment &...
I have a 2005 dodge stratus how do I clean the air filter and how do I get to the air filter
id suggest replacing the air filter the filter is located in the cannister its black usually square has a plastic accordian hose that goes to it and its usually on the passenger side of the car under the hood.also it can be located on the passenger side.
Jun 18, 2010 | 2005 Dodge Stratus
The machine says "replace ozone filter" i did that but the message won't reset itself. is there something i can do to reset it?
On most models of Color Bizhub machines, to reset the ozone filter message you must go into service mode. Press the Utility/Counter button on your operation panel, select meter count, then detail, press stop,0,0,stop,0,1. This will put you in service mode. Find and press counter button, Locate life counters, and clear ozone filter. You will not be able to clear some of the counters in this menu. They are automatically cleared when the items are replaced.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
Where do I find the Paper Dust Remover/Ozone Filter and the Transfer Roller Unit?
I believe the filter is located on the right or left side. The "Transfer Roller Unit" is the foam roller inside the right door.
Apr 07, 2010 | Konica Minolta bizhub C351 All-In-One...
I need to replace the Ozone Filter on our BizHub C351 but I am not spotting where it is hiding on the machine? Any clues to lead me to the right spot?
Mar 23, 2010 | Konica Minolta bizhub C351 All-In-One...
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
I want to know how remove the filter to clean or replace on my fm744h fantom vacuum
The hepta filter has a place on each side to push in.The top
comes off and the filter is inside.The new one is about 24.00.
Remember to clean the dust filter .This is located in a chamber
below the cannister . Remove the cannister and there is a grey plastic tab,it will comes up and dust filter is right there-pinch
it and it will peal out.It can be hand washed and air dried.
Parts at TotalVac.com
Nov 28, 2008 | Fantom Vacums FM744H Vacuum
Konica Minolta bizhub C450P Laser Printer Logo
995 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
