Question about Whirlpool Washing Machines
Water leaks into washer after cycle is complete, and fills the machine.
catriver
  • 878 Answers
SOURCE: Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Posted on Apr 15, 2007
aborcass
  • 2651 Answers
SOURCE: KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Posted on Mar 07, 2008
SOURCE: Filling With Water
I recently had the same problem. I checked the end of the air hose coming from the tub. It had a tear in it right at the connection. I just cut off the hose at the tear and placed the hose back on the connection.
Posted on Jul 18, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
  • 574 Answers
SOURCE: My Maytag washer keeps filling
Could be that your water inlet valve not closing completely or simply not getting a signal to close
Posted on Aug 26, 2009
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Slow leak under unit cannot find problem. what specific should i look for?
It is most likely a hose connection from the pump to drain. What you could do is fill up the washer with cold water and color the water with food coloring let the washer rn thru a cycle. on its completion of the wash cycle and after it drains do not let it fill back up. Turn the water supply taps off and til the washer over on its front. With a tissue,(white), find the spot arond the connections where the color has dripped from. Repair that conection and with the washer back uprite run thru a complete cycle to test for leaks as well to purge the color out of the system. You either must do the later or run like h--l if the wife gets that color on her clothes. lol
Sep 28, 2010 | Kenmore 23822 Top Load Washer
The washer fills after the cycle is over.
If water is leaking back into the washer after the wash cycle is completed, then the problem is with the water inlet valve. It relatively easy and inexpensive repair. It the part that connects to the hot and cold water lines.
Aug 31, 2010 | Whirlpool GHW9100L Front Load Washer
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
The conditioner drwaer fills with water after each cycle and the machine leaaks during each cycle
Check for pluged drain to washer ,check fill hoses for tighten fittings and good washer inside. (seal). The conditioner container may have a valve that has gone bad or pluged up. To much conditioner can plug this part up, Should check with a appliance repairman. If this is electrical, he should do the job for safety. Hope this might be of some help.
Jun 02, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Frigidaire lws3312d washer not filling up
check the water faucets on the wall and make sure that both hot and cold are completely open.
check the water inlet hoses for any kinks or leaks.
Nov 05, 2008 | Frigidaire CWS3600AS Top Load Washer
Leaking Washer
Changing this solenoid could solve your problem. Also try to turn off your faucet if possible after you hv finished your washing.
Dec 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
115 people viewed this question
Dan Webster
Dan Webster
Sal De
