Question about Husqvarna 22 hp 42" Yard Tractor YTH22V42
Was mowing right along and the mower deck just stoped working the tractor is only 5 years old
  • 718 Answers
Check your drive belts first see what happens.
Posted on Aug 30, 2010
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Mower deck draft arms keep coming loose from spring pins.
put a washer between the arm and pin,use a zip tie to hold them,put them on backwards,stop hitting things that will move them.
Jun 26, 2015 | Garden
How do you level the mowing deck?
There should be an adjustment on both sides of the deck. Move the nut up or down to raise of lower it.
Jul 03, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have a John Deere tractor LA145 Yesterday while mowing the mower blade suddenly stopped working. Turned on and off several times with no luck All pulleys and belts seem to be intact. There was nothing...
Either you need a seat switch or the reverse switch has failed.If the deck will engage while you are pushing down the forward pedal then the rio or reverse switch is not working or it's out of adjustment.If you can not get the deck to engage at all then the problem is likely the seat switch.
May 04, 2010 | Garden
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
May 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 22 hp 42" Yard Tractor YTH22V42 Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
