Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer sport ht - error codes
I am getting error code f-21 and 5d on mi washing machine ,I check drainer hose it looks like to be draining ok.
  • 12 more comments
  • ibandaey May 23, 2008
    My Whirlpool duet has error 5d. Washer seems to finish the load but after it is done this code is in the display. Anyone know what I can do or what this means???
    Thanks
  • Kell Le May 27, 2008
    I have a whirlpool sport duet ht and get the same error code F 21 flashing.
  • Anonymous Jul 17, 2008
    Getting the same 5d error code. Machine not rinsing or draining. any advice?
  • nmarino Jul 17, 2008
    Same thing here. It says 5d in the display area. I think I'll have to call them to find out. The manual says nothing about it. The clothes are coming out as if they aren't being rinsed enough.
  • Anonymous Nov 06, 2008
    I'm, getting a F21 error code this machine has done this off and on for the last year. I checked the clean-out nothing there, now what?
  • Anonymous Jan 13, 2009
    my washer will not wash all the way I keep getting a code (where it shows the estimated time)Sd and I have to put it on the drain cycle so I can open up the washer. What can I do about the this
  • overflowing Jan 22, 2009
    We removed the front panel and found nothing but a 1" foam square. We restarted the load and first got the S5 error...then it gave us the F21 error again :( Any suggestions?
  • Anonymous Apr 16, 2009
    wont spin just goes back and forth trying to start spinning for spin cycle. then will give code 5d.
  • mdttcato Feb 23, 2010
    I HAVE A PROBLEM...After cleaning out the drain, which corrected problem number 1, I can not get the power to come on. This began after unplugging, then switching the breaker for the laundry room per whirlpool customer service. Any suggestions???
  • gleyva Oct 06, 2013
    Any of you got an answer how to fix this problem?
  • Anonymous Mar 13, 2014
    F 71 error code whirlpool duet HT frontloader
  • Anonymous Mar 24, 2014
    My washer is flashing the code F27 but the hot water will not stop flowing into the washing machine. It seems to be draining fine
  • Anonymous Mar 28, 2014
    duet sport ht
  • Anonymous Mar 30, 2014
    Sounds like bearing on back of wash drum has balls rolling around? Whirlpool duet sport ht
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
Posted on Jul 28, 2008
  • j2m20s75
    j2m20s75 Jun 10, 2012
    Great solution that is easy to do. Couple screws and a twist of the drain clean-out cover and there it was: 2 screws, about 50 coins, a gold braclet, an angel pendant, several rocks and a load of lint and scuz. Do be prepared with a bucket or towles to catch the water that will come out. Took about 10 minutes.
I am TIRED of my Whirlpool Duet. It's the worst washer I have ever owned! I am tired of searching the internet every time I get a new error code, tired of cleaning the drain pipe, tired of re-inserting the plug in the back (due to excessive vibration), tired of hearing coins and got knows what else rattle when it's spinning. First thing Monday morning, I am getting me the "old-fashioned" style washer. Duet is HORRIBLE!
Posted on Feb 27, 2011
  • angie Mar 21, 2013
    I agree its the crappiest washer I have ever had....i will NEVER buy another whirlpool
    Genius:
  • 1,073 Answers
Check the pump cean out on the frount of the pump unscrew the plug, be prepaired for some water and also unplug the washer before starting
Posted on May 09, 2008
We received the same code of s5 and it not spinning out. We took the front cover on the bottom off and cleaned the drain. We found 2 small barrets, bobbi pin, part to a door, a 22 bullet, a bit, 40 coins and my thong panties! With a lot of lint and hair. UGH! We will be cleaning that more regularly! THANK!
Posted on Nov 16, 2009
    Habit-Forming:
  • 4 Answers
Hey The solution worked. Take off the front cover on the bottom, then there is a drain clean out. Make sure you have towells, as water will drain out. Removed lint and items, I had a nail, bobbypin and lint that clogged the drain. Once removed, worked fine!
Woodland Gal.
Posted on Oct 25, 2008
  • Sailormoon33 Feb 23, 2012
    It does work but u need a 1/4 nut to unscrew the front of washer this would help for people who can't look st the size and tell
I too had the 5d code but I just fixed my washer thanks to the above posts! It was a clogged drain plug. I found 2 socks, a couple bucks in change, a tie pin and a gold braclet, a marker and a crayon. Jeeze!!
Posted on Sep 11, 2009
Thanks for all the advice. I checked my lint filter and and found: approx 75 coins (no kidding), bobby pin, 3 marbles, 4 airsoft BBs, 1 small nail, 1 childs ring, a few pieces of gravel and other misc items all bound tightly together in lint and silt. I can't believe the unit was washing at all. Looks my problem is solved.
Posted on Nov 09, 2008
Thanks for the tips on here. I am not mechanically inclined at all but with all the great info here, I was able to clear ours out - final tally 13 coins, 2 little girls socks, and eyeglass cleaning cloth, a doll's bib, and some miscellaneous junk - unreal!!! Hex nuts on the front of the machine are 1/4" to get the lower panel off. This info helped too - there's a link down a bit for a repair manual for older models that was helpful.
Posted on May 19, 2010
I hate my Whirlpool Duet Sport. I had all these problems (S5 error code, door not unlocking, etc.) and had the service company out to look at it SEVEN times in the first 2 years! Finally the warranty company sent me a refund of the replacement value.
Posted on Feb 22, 2010
    New Friend:
Thanks for the posts everyone. Our washer exhibited the error code 21. I cleaned the washer trap and thought great this is fixed. Started the washer and then got the error code 5sd. Hmmm, wife had added more detergent ( HE of course ). Unplugged washer for a few minutes, tried rinse cycle and nothing! Just error code 5sd.
Back to square one. When I reopened the trap I tried spinning the impeller on the the drain pump attached to the trap. Though it turned it did so reluctantly. Managed to get one finger inside impeller housing and felt a bobby pin stuck between the side of the impeller and the impeller housing. Removed pump ( that was fun ) gave it a good shake and out popped the friggin bobby pin.
Put everything back together and now I\'m running the rinse and spin cycle to get rid of any excess detergent. She\'s back up and running!
So please double check the free movement of the impeller when you\'ve got the trap out. It may save you this added aggravation.
Thanks Again to everyone who posted their solutions.
Posted on Mar 07, 2014
    New Friend:
CAll TO YINO SERVICES & REPAIR INC
786-402-4946
Posted on Jun 21, 2014
    New Friend:
Yes just finished my repair would be a lot easier if sheet metal screws were slotted had to use 1/4 inch wrench took much longer that way!!!
Posted on Jan 19, 2013
  • gallenrealto Jan 19, 2013
Error code s5: clean out filter full of silly bands, lint, coins, and a swiss army knife!
Posted on Jan 23, 2011
I keep getting a dl code when starting my washer. Im assuming its the door lock, but not sure
Posted on Oct 26, 2010
F21 According to Whirlpool:
"This error code indicates that drain times are longer than expected.
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the search tool below."
Also
"Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations."
Regards,
Eric P.
Posted on Oct 18, 2008
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Regards,
Eric P.
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
We have a Whirlpool Duet HT washer. Due to the freeze, and burst pipes, we haven't used it for a few days, but got the cold water line fixed. However, when we started the washer, it came up with an F20...
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you do not have the hot water line fixed, then that is where your problem is. The washer looks for water supply on both lines. It will still work, but you will get this error.
Feb 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Hi, my name is Uwe Gemba. Our duet sport Ht is not draining the water out. error F-21.
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
(Courtesy JSRock)
Thanks for using FixYa
Dec 21, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
What is error code F-21 , and how is it resolved?
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Jun 28, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My whirlpool duet sport washer keeps bringing up these codes f- and sd. What are these
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Thank you
May 29, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
16,578 people viewed this question
Dan Webster
Dan Webster
Sal De
