Question about IBM Infoprint 1622 Laser Printer
935.19 Service Printhead Error - IBM Infoprint 1622 Laser Printer
Service printhead error 114.02
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to "RIP Board" on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
"RIP Board" on page 4-11 If this does not fix the problem replace:
Yellow Printhead Assembly - Go to "Printheads" on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the "Printhead Adjustments" on page 4-1.
Feb 15, 2014 | Office Equipment & Supplies
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
What is 931 service error
Hello my friend,this is printhead error,check connections at both ends of cable for corosion or oxidation,reconnect them.Also can be system board error.You can check the operation of
the printhead shutter and clean the printhead window with a lint-freecloth folded over a cotton swab; do not use a bare swab and do not use any cleaning fluids or water on the printhead window if you see the defect on the photo conductor.Good luck:)
Feb 03, 2010 | Lexmark T642 Laser Printer
Service Error 5200 comes up on printer status. What is the procedure for solving this error?
5200 is a temperature error of the printhead. The only repair is a new printhead, you will find the part number on the side of the printhead, it starts with
QY6-
Jan 31, 2010 | Canon i9900 InkJet Photo Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
931.01 Printhead Service Error
there is a Printhead error - No first sync
Dec 21, 2008 | Lexmark X342n All-In-One Laser Printer
Error message re printhead.
To resolve the error condition:
  1. Open the printer access door.
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead
To reinstall printhead follow the link.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Print head problem
Dear palia1234,
Blinking in orange 5 times indicates that the printhead error occurs. You need to replace the printhead with a new one. But be careful before replacing the printhead, check your printhead if any smoke smell or indication of short circuitry present. Replacing the printhead in this case will harm new printhead. You'd better to take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 08, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
IBM Infoprint  1622 Laser Printer Logo
943 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
