Question about Ford 8N Tractor
My oil pressure dropped on my 8N while bush hogging. Then it jumped up and down.
  • Doug Brough Apr 26, 2013
    I have a 1949 8n last year it run fine,I started the summer and it had no oil pressure and it raddled in the engine so I shut it of fast what may be the problem/
Oil pressure vavle in front of the motor is bad or the spring is weak.
Posted on Sep 03, 2010
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Hood fan vibrates very loud. if i put pressure on it..squeezing both sides...it quiets down. How can I resolve this issue
Remove screws holding fan and drop it down. Slide fan blade off shaft of motor and try cleaning it and look for distortion of blades from heat, plus check shaft for play back and forth. If shaft is sloppy, probably have worn bearings/bushings and should be replaced. Couple drops of oil around shaft may help temporarily.
Apr 25, 2014 | RVs
I have a 97 wide glide with16,000 miles oil light stays on and a ticking noise started i shut off bike right away, could it be oil pump not working making lifters and cam to make a ticking noise?
doubt if it would be an oil pump
the copper shavings are more likely to be from rocker shaft /arm bushes
If the bushes have failed then there will be a reduction in oil pressure putting the light on
cam shaft bushes and big end bearing failure is normally a grey metallic in the oil
talk with an accredited shop for a proper diagnosis.
May 07, 2012 | Cars & Trucks
1995 Ford Econoline 150 with 302 engine. Oil pressure indicator starting dropping when idle speed went down, Had a new oil pump and sending unit replaced, still does the same thing. Has 190K on it, now as...
When you had the pump replaced did anyone look at the rod and main bearings? 99% of all low oil pressure problems I've seen has been directly related to bearing wear, not a bad oil pump.
Replacing the pump will give you slightly better pressure temporarily but that won't last very long.
Verify the actual oil pressure using an external mechanical gauge. If it's low (likely it is) go back into the oil pan and use plasti-gage on the bearings to measure clearances.
In reality though, in an engine with that many miles, it's best to either completely rebuild or replace it though.
Sep 10, 2011 | 1995 Ford Econoline
Oil pressure problem
Replace your oil pressure sending unit. Usually costs about $10.
May 25, 2009 | 2000 Ford Ranger SuperCab
Oil pressure good at startup, after driving 10 or 15 min it gose down and out when stop. but will go up when givin gas. dose not knock or tap.
Sounds like a worn engine.....the more clearance you have on the crank bearings....the more oil leaks out from them....lowering the pressure......but that doesn't mean you can't run it .
As long as you have some higher pressure when working the engine.....I wouldn't worry about it.
It is normal for the pressure to drop a little at slower engine speed when warmed up.
Why not put in a thicker oil.
Try a 20w40 or 20w50 or straight 40 if your weather is warm to increase warm/hot oil pressure.
Feb 18, 2009 | RTO Ford----oil Pump-drive Gear 2n,8n,9n
Ford 8N Tractor Logo
234 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
