Low volume on left channel of Sony STR-GX4ES
I have a vintage (circa 1989) Sony receiver (model STR-GX4ES) connected to a CD player and a speaker set. It had been in storage for a while, but was working beautifully when I first set it up.
Then, the sound in the left channel dropped dramatically and has static. I have isolated the problem to the receiver. When I swap the speakers and the wiring, the problem still occurs on the left side. When I plug headphones directly into the CD player everything is fine, but when I plug directly into the receiver, I get no sound on the left side of my headphones.
I also tried wiring the left speaker to the B channel (leaving the right speaker on A). When I turn the volume way up, I do get sound but there is static and of course, it is way out of balance with the right speaker.
So...what is going on here and is this something I can fix myself? Thanks in advance for your help!
  • LvsMusic May 08, 2008
    Hi Dan,
    Thank you for your blisteringly fast response!
    Although I haven't worked on electronics previously, I am certainly willing to learn how to solder. Given the age of this receiver, should I try fixing it myself (recognizing that I might do more harm than good) or take it in for service (not easy or cheap since I live far from civilization!)?
    I would love to repair this component since the sound is great, but I know it also might be time to move on to 21st century technology! What would you advise?
    Thanks again!
    Les
  • 4,234 Answers
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
Posted on May 08, 2008
Sony str-de185 left channel very scratchy and poor; not speaker, wire, or connections
Could be an open resistor in the amp for that channel. Might have to have a pro look at it.
Mar 26, 2013 | Sony STR-DE185 Receiver
Speaker Imedance Matching - Sony STR DE 997 receiver with 120Watts - 8 ohms output with Benz 6 ohms..Tower Speakers
hi pawanh75,
thanks in advance for a very informative setup that you have.
Here are some of possible mods , only if you like and can DIY
( or have someone to help you )
• Using a 6 ohms impedance for an 8 ohm impedance amp clearly
denotes that it heats up the output stages.
(please forgive my very technical words)
• One way to lessen the heat is to install a blower .
Use a 220V blower on top of the receiver.
( air should be in going up direction ).
• Before I proceed further please indicate if having the speaker
connected and having a zero volume , and just letting the receiver
in an "On" state deliverately produce heat on the receiver, or just
when the volume is at medium to high level.
If it s running hot at zero level with speaker , please post.
If it is running hot even without speaker, post also
• It may also helps , if you have a powered subwoofer ( for the low's),
and set settings on your receiver to "small"
Let me know what you find to help you further.
Sep 11, 2012 | Sony STR-DE997 7.1 Channels Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Power out rms- 4 o 8 homs?
I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
I founs some articles and For Sale posts:
http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
"Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
Jan 02, 2011 | Sony str-4800sd stereo receiver with...
Right channel low volume on Sony STR-685
Here you go buddy:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C225335&fes=true&mdl=STRDE685
Sep 20, 2009 | Sony STR-DE685 Receiver
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Output
When you change the selector switch, do you hear the relays inside the unit? Is your muting button activated (found to the lower left of your volume knob)? Do you have speakers connected to A or B or both?
Dec 23, 2008 | Sony STR-DE685 Receiver
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
Sony STR-DE597 6.1 Channels
Repair time ...circuit board to front channel has a fuse prob or capacitor
May 24, 2008 | Sony STR-DE597 Receiver
Left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Feb 21, 2008 | Audio Players & Recorders
413 people viewed this question
 Grubhead
Grubhead
