- Disable Flash Player and YouTube Video Download Plug-Ins.
- Upgrade the Display Driver.
- Clean the Associated Registry Entries (must use reliable program RegInOut for it.)
- Run Internet Explorer in Safe Mode.
- Reset the Default Settings.
- Clean Browser Cookies & Temporary Contents.
After performing these tips your problem will be solved.
Dear Friends Don't worry about this thing just remove the temp and cookies and try again some time if you are not remove or delete the temp & cookies they will block the site or internet work slow. If not luck then check you internet connectivity, and type this command in command prompt
Go to the Run and type "cmd" (without quote)and type "ping google.ca -t" (without quote") check if you getting the answer like this.... Answer "Reply from 72.30.38.148 bytes=32 time=893ms TTL=48" (The numeric will depend on you internet connection or speed so don't worry if you get difference number) Answer Request Time out if you get "Request Time Out" then you internet is not working try, restart you cable modem or wireless router. Thanks to Visit on Fixya... Prashant
If you are using the beta version, this is a normal scenario. If you are using IE 8 latest check whether you have downloaded the proper version which suites your windows platform. Go to add remove programs-> windows components and select internet explorer to remove it. Then re-install the new one. Make sure you patch it usually.
