Question about Sony Cameras
Dropped in river for about 5 minutes. Later tried to blow(with mouth) all the water I could out. Is it savable? I charged battery but it doesn't turn on now..Any thoughts or help? Also put camera in materials to draw moister out. Ron
  • 6,831 Answers
Hello
Ron
Well, the camera was submerged for 5 minutes as you said, at this point we are talking about a whole circuit blowing/short circuit.
If you are so lucky, it is only the circuit, then you might have to look at the CCD's, and this is just to name i few.
You can try putting your camera into a sealed container filled with 2 cups of rice for about 24 hours. If that doesn't work, it's done.
Sorry.
Kind regards
Andrea
Posted on Aug 30, 2010
It has been charging for 5 hours like this and doesn't turn on. What do I do? It turned on twice but stayed at 1% for about 10 minutes but then shut off again. I have no idea why it is doing this and
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 11, 2013 | Cell Phones
2006 chevy colorado out of the blue will not start. just makes clicking sound. Started it drove out of garage shut it off. Went back out 5 minutes later won't start. Clock even reset.
Sounds like a bad battery. A number of chain auto parts stores will check it and your charging system free. Before that, if your battery has removable caps, check the water level, if it's down, fill to the bottom of the fill rings and charge the battery, if you have a battery hydrometer, all the cells should have about the same charge level, if one or more show a lot lower than the others, battery is probably bad. Hope this helps.
Jul 29, 2012 | 2006 Chevrolet Colorado
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
Wife used cig lighter adapter last night to blow up air mattress this morning new battery less than 1 month old wont start car. charged battery now when i turn the ignition key to start car the car alarm...
turn the igntion on, don't start, let it set for ten minutes Turn it off for 5 seconds then try to start it. If it lost memory for some reason and doesn't start . then do this three times , after the third time start it. that is the relearn procedure. Have a charger on it for the 30 minute relearn. Relearn is on for ten m off five s on ten off five on ten off five then start
Jul 02, 2011 | Chevrolet Lumina Cars & Trucks
I have a 10KW SIEMENS generator Model #0059090 - Cat#ASGNO10RBS, it was installed May 26-2011.Generator workrd fine after runing all the test required. We had a very short outage less then a minute, after...
Most of those chargers have a fuse in line between the battery and the charger which you should check. They are two stage chargers meaning when there is a large voltage drop, they go to a high rate charge until battery voltage reads about 14.3 - 14.6 VDC then drops to a float volatge and normal float voltage should be about 13.33 VDC. When they go to a high rate the light turns red, when they go to float the light turns green. When the fuse blows the light stays green because it doesn't see any voltage but the charger isn't doing any work.
Jun 23, 2011 | Generac Electrical Supplies
My phone is 3 yrs old. Lately the battery will not keep a charge. I charge it until it is fully charged, however if I talk for more than 5 minutes the phone logs off and dies. I turn it back on and the...
It sounds like your battery is faulty. 3 years of use is enough to wear a battery out. Try replacing the battery and see if the problem clears up. If it doesn't your phone may have an internal faulty, but I am going with the battery.
Apr 15, 2011 | LG enV VX9900 Cellular Phone
My Kodak m1093 stops charing in 5 minutes on a new battery. The old battery was dropped due to i thinked it goes dead but that was an lens error that i fixed later. when i used a new branded battery, it...
Hello, try putting in more expensive re chargeables. And if that doesnt work, get yourself a discharger. This machine discharges the batteries safely and allows them to fully charge to their full potential. There are more stronger batteries coming out every week, just try a couple and see how you go. Also have you tried using a different charger? Perhaps the charger may not be 100% all of these things make a difference. I hope I have helped you.
Mar 28, 2011 | Kodak EasyShare M1093 IS Digital Camera
Phone turns off every couple minutes and then turns on by itself.
What I would do is turn it off completelly for a few minutes. take out the battery and let it cool down for a few minutes. If you have a battery that if fully charged put it back in and turn on your phone. if your battery is not totally charged, charge it. A phone whose battery is not fully charged may cause your phone to flip out. sometimes it's also water damage to the phone that causes it to turn off on its own.
Water damage happends from body heat, from taking it to the bathroom when you're in the shower, or from putting it directly in water.
Hope this helps.
Mar 25, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
