Question about Pool & Spa
My husband removed our AO Smith pool motor from the pot/collection basket and now he is having trouble getting the clamp assembly-volute back on. This is the clamp on the outside of the seal plate and the volute and it has a knob where a screw is thread through. Any suggestions?
    President:
  • 1,378 Answers
Use a synthetic lubricant like magic lube and lay a bead all the way around in the groove the o-ring sits in. Press the o-ring into place causing excess lube to ooze out. Wipe your finger around the whole mess to coat the whole o-ring and then be sure to lube the o-ring on the diffuser.
Once everything is coated the large o-ring should stay in place and the pump half should insert fully into the volute so you can install the band.
John
Posted on Aug 31, 2010
Rcvd new pentair 1 hp pool pump replumbed and did the electrical connection. motor get real hot and shut off. i used the correct 12 ga wires and wire it for 115v. do you think i got a bad pump. it did...
Assuming everything is electrically correct, the motor probably has a short in the winding somewhere. The motor should have a one year warrantee on it. Any pool store ought to be able to trade it out for you.
Sep 14, 2013 | AO Smith 2hp Pool Pump Motor Ao Smith...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I have a A.O. Smith pool pump (Model #C48L2PA105C5 & Serial #04609FM) and there is no suction at all
hayward ?? good chance the impeller is broke or it could be plugged with trash make sure you pump basket has no cracks , see picture on how 2 remove your pump .find your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_7_43_54_pm.gif
Sep 23, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
Hi, I have a QC 1072 A.O. Smith pool pump motor. How to get the impeller off? Which direction does the impeller spin off? Where to but impeller and seal? Thank you very much Greg
The impeller is just screwed on the shaft. COUNTERCLOCKWISE to remove. Some have a screw in the center attaching it to shaft. This is removed by by turning CLOCKWISE.(reverse threads) Remove back cover and secure shaft with a wrench. There are flats on the shaft to hold it. You might need a large pipe wrench to loosen impeller. Wrap with rag so you don't damage impeller.
May 18, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
Replaced ao smith mtr with ge marathon, now have leak?from bottom
Thank you for posting your question here on Fixya.com.
Check the volute o-ring for damage. It sometimes moves as you re-tighten the band around the pump halves and gets pinched. If it was, replace it. You may also need to replace the pump seal and insert if the pump is old enough to have had one. Whenever you change a motor you should also replace the seal.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Sep 08, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Removing pool pump impellor from motor shaft
Separate pump and motor. Remove diffuser. Remove back cover from motor. Motor shaft has either a slot for a screwdriver or a flat area for a wrench. Hold shaft and unscrew impeller.
Feb 24, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
How to remove the end cap on a motor
Most models have two screws on the back then you just pull it off. Some will have a small cap you just pry off about the size of a half dollar.
Jan 31, 2010 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Oct 21, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Pool & Spa Logo
106 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
