Question about Hotpoint HSS25GFP Side by Side Refrigerator
The freezer goes on and off and it melts - Hotpoint HSS25GFP Side by Side Refrigerator
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
Ice build u p and leakage in freezer
you have a blocked drain in the freezer,when the machine goes into defrost the heater comes on and melts the frost off of the evaporator coil,the water melts and goes down the drain hose under the coil and leaks down to a drip pan near the compressor where it evaporates from the heat,your drain is blocked and the water is leaking onto the freezer floor and will drip out onto the floor,i use a steemer to blow out the drain line,shut down the machine or unplug it,melt out all the ice with hair dryer,depending on your model you might have to remove the back inside wall of the freezer to get at drain hole,you need something to push the **** out the drain hose,you can try a turkey baster or air from a compressor or a shop vac set it to blow,when you think it's clear pour a cup of hot water into the drain,if it drains down you're done if not keep hitting it with heat and air to push it through.
Sep 01, 2012 | Refrigerators
Water accumulating under veg.bins. Do not have ice maker hooked up. Whirlpool ET20DKXXN10 Model Mfg. date 1992.
you have a blocked drain in the freezer.when the machine goes into defrost a heater comes on and melts any ice that built up on the evap coil,the ice melts and goes down the drain and into a pan at the bottom where the compressor and condenser coil is and evaporates from the heat,your drain is blocked so the water can't go down the drain and it has nowhere to go but down into the fridge section.unplug the machine,remove all the food out of the freezer,remove the shelf and the inside back wall of the freezer.you might have to heat up the back panel with a hair dryer to get the wall out,when you have the back wall off melt any ice with the hair dryer,now you have to clear the drain,i use a steemer to blow down the drain but if you don't have a steemer stick a screw driver into the hole and the metal on the driver will heat up and help melt the ice,when you think the ice is melted in the hole get a turkey baster or something that will blow or push anything in the drain out,then pour hot water into the hole,if the water drains down then you're done if not keep hitting it with heat and hot water and try to clear the drain.hope this helps.
Sep 13, 2011 | Refrigerators
Water accumulates in the bottom of the freezer, model FRS26ZRG, then melts out onto the floor
the water drain is clogged, when a freezer goes in to a defrosting cycle it MELTS the excessive ice build up and the water drains throug a drain (usually in the back of the freezer) than goes in to a pan under the freezer to evaporate until the next defrosting cycle, so check the pan if it's not full of dust or debrie (cat toy HA!) as well...
Cheers!
Aug 31, 2011 | Blenders
HI, the freezer is tripping out the fuse box and there is a burnt and melted area on the plug that goes on to the 'black bottle' in the bottom of the freezer. is it possible to get a replacement...
just replace the plug as you would any appliance that comes without one.a loose connection/socket is a prime fault for heat buildup and cause the connection to melt.
Nov 05, 2010 | Refrigerators
I have water comming out of the freezer at times and a pool below the bottom shelf.
You drain has frozen up probably because of a clog. Take the bottom door out and right at the rear bottom of the freezer back in the middle you sill see a drain. When the freezer goes in deefrost the frost will melt on the evaporaterr lines and must go down under the freezer yours does not and when the freezer comes on that water freezes. next time it defrost it heats that ice and the melted water come out the front of he door. clean that drain.
Jun 06, 2010 | Hotpoint HSS25GFP Side by Side...
Whirlpool mod#et18pkxgwu top freezer,no ice maker. water leaks from freezer down intt the bottom ver. bins.
The Water is coming from the defrost cycle melting the ice on the evap coil.  There is a drain that goes to a tray near the compressor where the heat from the compressor evaporates the water.  That drain is clogged.  Take the back panel off of the freezer and unclog the drain hole.  Most of the time it is iced over and the ice needs to be melted.  It could also  be clogged where it comes out at the compressor.
Oct 25, 2009 | Refrigerators
Ice melts in the bucket on and off...
1check for frost 2 check light stay on 3 condenser fan 3 check door stay open
Mar 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water from defros goes to the bottome of refrigerator
the drain from the freezer can get stuck with ice or other stuff. The tough part is removing the cover from the freezer to expose the coils and the drain. Check the defrost coil while you're there, I use a hair dryer to melt the ice.
Mar 21, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Noise
When the freezer goes into defrost mode, some thumping/popping noises can sometimes be heard as the defrost heater melts the ice built up on the evaporator. Quite normal.
Nov 01, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
