Question about RTO Case W14 1570 2090 2290 2294 2590 3594 4490 Water Pump
Djohann45case 2290 tractor does not move when shifted into any gear nor does power shift move when tractor is running. Power shift can be moved when engine shut off. Pto , steering and remotes work just fine
2 Suggested Answers
  • 66 Answers
SOURCE: 2090 case trasmission problems
That's because you have two separate pumps controlling each. My best advice is to get a farm mechanic to take a look...it may be a simple seal to a need for a rebuilt pump. www.nyagparts.com
Posted on Jun 01, 2010
I have a 1953 fordson major tractor she will go into any gear with the engine running without clutch but wont move
Interesting, sounds like a shift link may be broken and not actually placing it into gear (even though you have shifted into gear).
Apr 05, 2017 | Garden
94 mazda protage car wont start no power and the gear shift wont move
Your gear shift won't move because there is an interlock which prevents taking your car out of PARK unless your foot is on the brake. Since the release solenoid is electric, and you appear not to have any electricity, you will not be able to move the shift lever unless you use the Emergency Release (described in your Owner's Manual).
As to your lack of power, perhaps a dead battery? (Good place to start checking!)
Jul 22, 2014 | 1994 Mazda Protege
In shifting though gears, with bike running and stationary, after shifting in to first gear hard to shift into neutral without tuning off power to bike.
The bike has a slightly bent shift fork. The repair is a pretty major operation and I don't recommend the casual mechanic attempt it. Below is a diagram showing how the shift drum moves slider gears for different gear changes. Please rate my answer. Thanks. tombones49_128.gif
May 10, 2011 | 2001 Suzuki SV 650 S
The gear shift is stuck in park. The wheel moves
Make sure you have brake lamps. The shift interlock solenoid is powered by the brake lamp switch.
Nov 15, 2009 | 1996 Ford Explorer
Clucth not disengauging....
try this.you have 2 shifter cables.one is select cable the other is shift cable.first put the transmission selector lever in neutral.then move transmission shift lever to 4th gear.depress clutch to if necessary to shift.move the shift lever to the 4th gear position until contacts stop.then you turn the adjuster turn buckle so the shift cable eye aligns with the eye in the gear shift lever.when installing the cable eye. make sure the flange side of plastic bushing at the shift cable end is on the cotter pin side.the cables should be adjusted so the clearance between the shift lever and both stoppers are equal when the shift lever is moved to 3rd and 4th gear. move the shift lever to each position and check that the shifting is smooth.
Jul 12, 2009 | 1996 Mitsubishi Galant
Cranks won't move
Sounds like the clutch is worn out. It sounds like it is slipping so badly it won't transmit enough power to move the bike.
As far as only going in 3 gears with the engine not running, are you spinning the rear wheel while trying to shift it? The trans shafts have to be spinning to be able to shift through the entire gear range.Try shifting it with the engine running and see if you get all 5. If you do, there is no problem with the transmission.
Jun 12, 2009 | 1994 Yamaha GTS 1000
This tractor will not shift into any gear. It had been getting slower to move and has recently quit moving at all. Replaced the drive belt today but still unresponsive. Gear shift moves to any position but...
check to make sure your brakes aren't stuck & if not make sure the belts are not shredded or really loose it could also be in the rear end it's self e-mail me @ wadembly@aol.com if i could further help thanks,wade
Jun 07, 2009 | Craftsman Garden
RTO Case W14 1570 2090 2290 2294 2590 3594 4490 Water Pump Logo
157 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
