Question about Garden
How to remove, clean and replace carburetor, on Troy/Built Pressure Washer with Honda GVC 160 Engine ?
4 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: I can't find an oil drain plug on a honda 5.5hp engine.gvc 160.
The engine drain plug is on the main (square) base part of the cylinder block. I think it is 10mm. There is a compression washer to seal it aswell so it might need a bit of extra pressure to start it undoing. This should drain your block almost completely.
For diagrams go here, you will need the engine serial number and prefix.
http://www.honda-engines-eu.com/en/welcome.html
For manuals go here,
http://www.honda-engines.com/Engines_owners_manuals/own.htm
Posted on Nov 14, 2008
  • 83 Answers
SOURCE: Honda gvc 160 not starting. cleaned the ventui & plug
Check the fuel.
Drain some of the fuel into a white contain...I use a paint can lid. If it yellow to orange in color it's bad. You can pour the fuel into your car to get rid of it. A car has electronics that will compensate for poor fuel quality, small engines don't.
Check spark.
Remove the spark plug and reinstall the wire. Lay plug on the engine block where it can contact it. Pull over the engine. You should see spark. If not change the plug. If still no, I give you further instructions.
Posted on Mar 31, 2009
SOURCE: I have a Honda GCV
Mine is doing the same damn thing! Trying to figure out how to take off the high-pressure hose connector because I need to inspect it for clogs.
Posted on Jan 08, 2011
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
Where is oil drain plug on troy-built waterpressure Honda GVC 190?
some small engines do not have a drain plug it may be at the bottom of the engine under neath where you can access it with a socket or hex key
or if none there , empty the fuel tank and pour the oil back out the filler tube
normally there is be around a pint (300 mls )
it may be a pain so check around underneath for the plug first
it is the same engine as used on lawn motors but with a different crankshaft to fit the pressure pump
Nov 08, 2015 | Garden
How come on a troy built Honda pressure washer when you push in the choke it stalls
if it stalls most case scenario would be the carburetor ,it needs the jet and fuel tube cleaned.
Oct 18, 2014 | Garden
Troy-bilt pressure washer 3000 max psi 2.7 gpm not getting gas
The carburetor ports and jets are likely clogged with gum from fuel that contains Ethanol. Avoid using any gasoline that contains Ethanol in small engines. Use only 100% gasoline. You can try the simple method first by adding some Lucas to the gasoline and a tad bit directly into the carburetor. Also, remove the bowl under the carburetor to see if it's gummed up and stopping the float from setting and rising. Simply clean the gum off with carburetor cleaner and replace the bowl. If this doesn't work then you'll likely need to remove the carburetor and do a thorough cleaning on it. Be sure to replace with new gaskets.
May 19, 2012 | Briggs & Stratton Garden
I have a Troy Built GVC 160 (2600 psi) pressure washer. I used yesterday afternoon without problem. Today, I can get it started, but it conks out immediately as soon as I engage the wand. I'd...
Make sure that the engine is set to full power. Lower the pressure to the unit with the pressure adjust knob as much as possible. Check the nozzle to make sure that no debris has entered and is lodged at the tip of the wand. Start the engine with the spray gun handle in the open /on position allowing water to flow thru. Allow the engine to run for a while to warm-up. Increase the pressure a small amount at a time to reach the desired pressure. To increase the life of the unit, do not use the machine at max. pressure setting. Adjust to about 75% of rated capacity and increase only for stubborn debris then reduce. Good luck
May 27, 2011 | Garden
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Check the fuel.
Check spark.
Mar 31, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Nov 13, 2008 | Garden
Garden Logo
260 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
