Hello i have a Samsung Ti-15x5 TV and i have a problem with the panel lock. I have no remote control for it and i need your advice on how to put this lock off or from where i can get a remote control that will work with this model. I live in Dublin, Ireland. Thank you
SOURCE: tv is locked
hi guys got same tv same prob......finally after hours of frustration found a solution.
steps:
  • Turn on tv
  • Press and hold the menu button (you will hold this through the next few steps till the menu comes up)
  • turn the tv off using the silver button on the back of the tv
  • push the button back in on the back of the tv
  • tv should come on and bring up the menu
  • using the channel and volume get to the menu with the v-chip controls there should be a reset menu button change it to on.
  • turn off tv using power button on front of tv.
  • turn it back on and problem should be solved
Posted on Dec 04, 2007
  • 8 Answers
SOURCE: Remote Control Codes don't work with my LCD TV
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
Posted on Mar 01, 2008
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central 2. Settings
3. Remote Control 4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
Posted on Mar 11, 2008
SOURCE: virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Posted on Mar 30, 2010
  • 1632 Answers
SOURCE: New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Panel lock samsung tv combi model Ti-14N3
how do i reset the panel lock on samsung ti-14n3
Jun 30, 2012 | Samsung CXJ1352 13 in. TV/VCR Combo
How do i unlock the panel lock on samsung portable combi tv vhs model no:TE-14N5
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV 1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
Jan 07, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
I have samsung combo tv/vhs, lost my remote control, I have bought new one universal remote, nearly everything working except AV option,most important for me, TV modes number is TI-20P1, I need correct...
I have a samsung TI 20P1tv/video. I was told I would play dvd also but every time I load one it says 'bad disc' what does this mean as the discs I load work every time with other tv.s
Am I doing something wrong? I have not got a manual .
I would be grateful for any help
Juliet
Nov 13, 2010 | Samsung VR8559 VHS VCR
My sis gave me an old samsung tv. It is just for my son and his x-box. Unfortunately there is no remote control. When switched on it is saying PANEL LOCK. Is there any way i can fix this. Model No TI-14N3....
hello you could try this The front panel of the COMBI VISION can be locked to prevent it
from being used by young children for example.
1 To lock the front panel, display the television menu by pressing MENU
2 Select the SETUP option by pressing the P ▲ or ▼ buttons the required
number of times.
3 Press the + button.
4 Select the PANEL LOCK option by pressing the P ▲ or ▼ buttons the
required number of times.
5 Select ON by pressing the + button.
Result: The buttons on the front panel no longer have any effect.
6 To unlock the front panel, set the PANEL LOCK option to OFF.Another option would be to buy a universal remote from say - Argos carefully open it and use your own batteries and use that remote to unlock the TV then return the remote to Argos or if keep the remote if the original is lost. i hope it helps
regards
shaun
Jan 12, 2010 | Samsung Televison & Video
Samsung 50" Plasma TV no response to remote ctrl & buttons
No need to exchange the Logic Board.
Need to exchange the IR modue.
Jan 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
How do i get the panel lock off my samsung tv?
Hello
you can use the control
click menu
and search the security of children
Inactive turn off
Jan 26, 2009 | Samsung CXJ1352 13 in. TV/VCR Combo
Samsung tv/video panel lock
if you have a universal remote ( i just used the all for one 4 model )
1 ) press the vcr button. 2 ) hold the magic button down wait for 2 red flashes. 3 ) enter code 0240. 4 ) press the power button on the remote tv will turn itself off. this will get the panel lock off the tv.
i have just done this after 30 mins of trying to work out why the panel lock would not come off with trying the tv codes. you have to use the vcr codes. my tv is now working and my grandson can play his playstation again with no problems just had it working.
dated 13:07:2010 1800pm. hope this helps someone
Dec 09, 2007 | Televison & Video
Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
Nov 30, 2007 | Universal Remote Control Activity Based...
Tape stuck
To unlock the front panel of samsung TI-15x5 get a universal remote control which should have TV code=702. Set TV1=702 and you will be able to gain some control of the TV+VCR. To gain control of the setup menu you use VCR code=289 and you will find menu in one of the bottons.
Oct 07, 2007 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
