Question about Microwave Ovens
GE dual Wave II microwave system handle broke off. can it be repaired??
SOURCE: BROKEN HANDLE FOR GE MODEL JVM1340WW002
Odd that we both have the same problem on the same model and same day..
If it's completely broken off, then you have probably pulled the threads out of the cheap plastic,, there are two screws that hold the handle on, one is easy to find/see, on the inside of the door, upper left corner,, to find the other, you need to remove (gently/carefully) the plastic bezel,, (all of this stuff is on the inside of the door), tap on it to find the plastic part,(bezel) and gently remove it by prying,, "prying" is an ugly word,, but since it snaps in, I'm not sure how else to tell you how to do it,, (Just go slow)
Once the bezel is removed, you can get to the other screw,
Now you have both screws, and know where they are supposed to fit later,,
On the back of the handle, the part that goes against the door, there are "studs" (plastic posts about 1/2 inch long and about the size of a pencil),, look closely into hole in the mounting stud, and you will probably see where the plastic threads have pulled out,, If thats the case,, the fun starts,,,
Go to lowes, or Home depot, and buy the smallest bottle of "Loctite" brand epoxy you can find,,
Look closely and the box will say something like,, "SETS IN 5 MIN.", or so,, get the LONGEST setting epoxy that they have,,
Now your back home and drinking a cold beer,, and ready for fun,, ---,Spray the screws with "non-stick" cooking spray, and set aside, (but handy)
Next,, match the handle back up to the door,, and identify which is the top,, mark it,, (masking tape and magic marker),,
I know it sounds silly, but you don't want to be fumbling around with it, while the epoxy runs back out of the holes and all over everything,, set the handle aside, but handy,,
Follow the instructions on the box, to mix the epoxy,, (work quickly)
Now,, using a toothpick or something similar,(disposable) dribble the mixed epoxy into the holes, (where the screws need to go), you don't need to fill them up, but a good 5 drops or so at least,,, WORK QUICK,,, remember to put it in both holes,,
Get ready to mate it back to the door, handle in one hand, a screw in the other,,
Top on top,, and from the front,,put the studs into the two holes
and as quick as you can, insert the screws,, you probably won't need to screw them in, (Threads are stripped out), but you may,, if so, just barely tighten them, just enough to "seat them, and the handle to the door,, It would be best to tape the handle in place until the epoxy sets,,
Check for ozzing,, dribbles, and drops,, and wipe it up now,, or it will be there forever,,
Sit back, put feet up, drink the rest of the beer, and watch epoxy dry,,, (Wait an hour to be safe) Besides, it gives ya more time to drink some more beer,,
Thats my best guess on how to re-attach the handle,, But I'm waiting until tomorrow to do it,, (out of beer)
Best of luck, Ted
Posted on Jan 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: how do you replace a broken handle for a GE Spacemaker II microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
On some models, the handle may rotate into and unlocked position then lift out.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Dual Wave II microwave
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
Ifthe fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
Whenchecking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
If you or someone you knowdecide to look into it, we have critical safety information anddisassembly information at our site, and our link is at our listing here on FixYa.
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE spacemake microwave handle door
Apparently the part number for the black handle is WB15X10020 and the white one is WB15X335.
You can order either and find find helpful exploded view diagrams here.
Enter the part number to order the part, and enter your model number to find the exploded views.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Dual Wave II microwave oven blowing fuse
It sounds like a shorted high voltage capacitor, a fairly cheap fix. But if it's good, I would suspect the high voltage transformer.
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 06, 2008
GE Dual Wave II Microwave System and Conventional Oven mICROWAVE DOESN'T WORK AT ALL AND OVEN WORKS BUT i DON'T KNOW WHAT OVEN TEMP CONTROL TO USE. i'M TRYING TO COOK SOMETHING AT 350% FOR 45MIN CAN...
I think I understand what you mean.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
I hope this helps.
Nov 04, 2010 | GE Microwave Ovens
GE Dual Wave Microwave System JKP61G0J1 The microwave has stopped working. The panel lights come on. The timer counts down, but the microwave itself does not run.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
h
Feb 26, 2010 | General Electric Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Nov 19, 2008 | GE JVM2050 Microwave Oven
How do you replace a broken handle for a GE Spacemaker II microwave?
Mar 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
246 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
