Question about Dryers
Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
Our dryer is 9 yrs old. It will start, get hot, begin drying clothes but stops within the first 5 minutes. If I open the dryer it feels hot, almost burning hot, but nothing is clogged. I've tried all the settings with the same result. Any suggestions for me before I call the Sears repairman?
    Genius:
  • 1,073 Answers
Sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
Posted on May 08, 2008
Stops before clothes are dry
Sounds like a motor going out . You need to replace the motor .
Jun 29, 2010 | Kenmore 65924 Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Dryer stopped working as it was drying, was real hot and will not start now. Kenmore 80 series electric
Problem common with blocked vent, need to check house vent...dryer has blown the thermal fuse. found behind the back panel small white fuse(usual two blue wires)....clear the vent and replaced the fuse. run on air dry first to check vent, should feel close to a hair dryer on low.
Jun 10, 2009 | Kenmore Dryers
Kicks relay when hot
Make sure the lint trap is clean,and the exhaust is clear. some models have safety switch to stop fire if unit over heats.
May 30, 2009 | Kenmore 64742 Electric Dryer
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Dryers Logo
467 people viewed this question
Top Dryers Experts
