Question about HP Photosmart M447 Digital Camera
HI I HAVE A TECHNIKA SH-Z735 A FRIEND USED IT BUT NOW THE PICTURE IS BLURRY AND I CANT TAKE ANY PHOTOS HOW CAN I FIX IT?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 30, 2010
When I take a picture it always comes out blurry. How do I correct this?
Search Results
    The Top 4 Causes of Blurry Photos, And How To Fix Them ...
    www.digital-photo-secrets.com/.../the-top-4-causes-of-blurry-photos-and...
    Out of focus An image that is out of focus will appear blurry. ... The first is to increase the shutter speed as explained above, The second is to hold your camera steady whileyou take the shot. .... It's always very helpful, and I enjoyed the video.
    Why Do My Pictures Come Out So Blurry? « Samsung Galaxy S3
Nov 30, 2015 | Cameras
I cant found the driver of my TECHNIKA SH-7065 so i can turn it into a pc camea
I will provide you a link that may help you downloading the driver you need.
Please click HERE to download the driver.
Jul 10, 2011 | Computers & Internet
Hi... i have added one pik of my friend in folder 'my photos' (phone memory).., 4 making that picture as his caller id pik., now i have removed dat picture from caller id but when m deleting the...
Give this a try. Plug in your mobile phone to the pc. Once ask on how do you want to use it either sync,mass storage or com port just select mass storage. Once selected go to photos folder where the picture that you want to delete is located. Just drag the pic to a different location like c: drive or documents and try deleting the picture from there. Once the picture is removed it would not appear anymore on your contacts.
Mar 11, 2011 | Samsung Lands Phones
My photos are coming out blurry can you tell me how to fix the setting?
hi, kindly check the lens glass if there's no moisture or finger print because sometime this will cause of blurry picture. after you clean and problem still occur the problem is inside of the lens unit and there's no setting can be repair this. if you have knowledge to repair electronics like camera you need to do is check the lens unit cable if not broken also lens gear if not worn out..
if you can't do this bring to service center and request for estimation first.
good luck and thank you my friend
Jul 18, 2010 | Casio Exilim EX-Z57 Digital Camera
Manual for technika sh-340t
When i turn my Technika camera on it turns its slef of in 3seconds and i have new battries why does this happen.?
Aug 28, 2009 | Cameras
Acer 5520 webcam is really blurry now and wasnt before.
go on line with a friend with your cam on, go into the cam settings and adjust the focus or contrast, ask your friend if there is a difference in picture, if this is the case adjust it until your friend says its ok, if it doesn't work clean the lens and try re-installing the drivers by putting the cam in a different USB port
Nov 14, 2008 | Acer Aspire 5520-5908 Notebook
User manual for technika SH1060 digital camera
I have solved the problem by returning the camera as it was still under guarantee. Thank you for your help.
Nov 09, 2008 | Cameras
Memory full
You camera is running off of the internal memory the camera manufacture does not give you much to play with. If you have a memory card in the camera and are still having the same issue going to the setup menu and find memory and set it to auto this will allow the camera to use the memory chip and used the internal memory when it is out. some times you can do a camera reset and it will correct most of the issues.
Mar 24, 2008 | Cameras
HP Photosmart M447 Digital Camera Logo
117 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
