Question about Casio Parts Cash Register PC Desktop
Ink is smearing across amounts. I have put in new one it is still doing it. What do I need to do?
  • Casio Master
  • 1,635 Answers
Smearing is usually caused by someone re-inking a roller or ribbon. The roller or ribbon must be replaced - never re-inked or damage can occur. If this is not the case, let me know the brand and model number and I'll try to help
Posted on Aug 31, 2010
Aspire 7535 7235 series
Changing drawers wont solve a problem like that. You have to clean the printing heads, and all the area around the printing head. It's best to let a proffesional do the job.
Apr 01, 2014 | Konica Minolta Office Equipment & Supplies
I believe my ink dried out in the holder bracket. I cleaned it with alcohol and replaced the -color and black ink cartridges with new, and can only get a littles ink smeared across the page on the first...
If ink dried out it's done. Recycle it and get new cartridge. If cartridge is more than 50 dollars don't buy it. Go to Walmart and you can by a brand new cannon printer with ink cartridge for $49.00
Jan 11, 2011 | Computers & Internet
How do I clean the printer nozzles as it leaves streekes on printed pictures?
If the ink is smearing, it probably is not getting enough drying time. The ink drying time is a period of time inserted between pages to reduce the chance that a page will smear the one below it in the output tray. This time is factored into the time between when the first page finishes and when the next page finishes. Printing will pause temporarily if more time is needed. The time it takes for ink to dry varies greatly depending on paper type, printer driver settings, humidity, and temperature. In addition, the paper and print settings may affect the speed at which the ink can dry:
  • Transparencies require much longer drying times than other paper types.
  • Some store-branded photo papers do not allow ink to dry correctly because of the coatings used in their manufacture.
  • Printing in Best mode can increase the dry time.
Resolving the problem If the ink smears, increase the drying time. To increase the drying time in Windows, follow the steps below:
  1. When ready to print, click File , click Print .
  2. Depending on your driver version, click Properties , Settings , or Preferences and follow the steps below depending on the option.
    • For Properties or Settings , follow the steps below:
      1. Click the Advanced tab.
      2. In the Extra Dry Time section, move the slider toward More .
    • For Preferences , follow the steps below:
      1. Click the Basics tab.
      2. From the Basics tab, click Advanced Features .
      3. In the Extra Dry Time section, move the slider toward More .
  3. Try a sample print and see if the drying time needs to be increased more.
To increase the drying time for a Macintosh computer, follow the steps below:
  1. From the File/Print Menu , select Ink under the General tab.
  2. In the Dry Time section, move the slider toward More .
Other steps that will reduce ink smearing If the ink still smears when printing, try some of the following suggestions:
  • Decrease the amount of time it takes for the ink to dry by decreasing the print quality to Normal or Fast mode.
  • Try printing on a different type of paper or on paper from another manufacturer. Paper formulas are different between manufacturers and may have a coating that causes the ink to be absorbed at different rates.
  • When printing large graphics or photos on plain paper in Best or Normal modes, improve the results by using heavier paper. Paper that is rated at 90 g/m2 (24 lb.) or higher will not curl or smear as easily as paper of a lighter weight.
Mar 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Getting black streaks across documents and pictures
Usual cause is defective bllack cartridge or it needs to be removed and excess ink cleaned from the face of it.
SOMETIMES using too heavy of paper can bend up an touch the bottom of the cartridges as tehy move across to page.
Also a paper jam can brush the cartridge and after that the ink is smeared on the cratridge face and will mark the paper as it moves across.
Using BAD refilled cartridges is a common problem.
Nov 08, 2009 | HP Photosmart C6380 All-In-One InkJet...
I have an Epson Stylus Color 860 and 880 printers that worked great for years. Recently I changed the ink and used a cleaning head and when I try to print the ink comes out smeared across the page. I put...
It's possible the parking pad (otherwise known as the cleaning station) that the printheads normally rest on have become clogged or degraded and as a result the pump is no longer able to pump the ink out of the pads or indeed out of the printhead nozzles as it should normally.
I'd be slightly worried that the "cleaning head" hasn't in fact damaged the parking pad area and reduced the effectiveness of the seal around the whole thing.
Unfortunately it's very difficult to explain without pictures so I can't provide a full solution but hopefully that gives you a couple of new avenues to explore.
Oct 13, 2009 | Epson Stylus 880 InkJet Color Printer
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Ink smears ,
You need to clean the print head until the smears clear up
Dec 15, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Ink smears
You need to clean it inside, use isopropylalcohol witch is good for cleaning ink
Dec 07, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Casio Parts Cash Register PC Desktop Logo
76 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
