We have an le code on our lg wm1814cw washer.
  • alucies Aug 30, 2010
    we have an le code on our lg wm1814cw washer, i saw someplace that this meant a motor overload, i need to know what to replace to solve the and how to get at it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
    Genius:
  • 1,417 Answers
what this code simply indicate means lock error from the screen of the washer is that the door of the washer is not properly close.
what you are to do to fix up the problem i to open the door of the washer then carefully close the door and make sure that all cloth are store in the washer before closing the door and also all door guild are in order.
thank you and thank for using fixya.
  • Oloyede Monsuru Aug 31, 2010
    hello,
    the problem did not need a part to solve the problem just apply
    the instruction giving to you or carefully unscrew the screws
    with a screw driver (technician tools )then trace the wire
    down to the panel clean it if there is an liquid or water
    around the panel and note the wire connection to
    avoid disconnection connected to the panel.
    thanks.
LE error code on my WM1814CW,it fills with water and drains but doesn't turn.
The LE code indicates a motor overload. The washer will not spin to avoid damaging the unit. First unplug the washer and let the motor cool for 30 minutes. When you plug in the washer, check if the unit has been reset.
The error often occurs if you use a non-HE detergent or too much detergent. In that case, do a Rinse and drain steps. Set the Spin Speed to No Spin by pressing that key several times. When that finishes, open the door and remove all of the clothes in the tub. Close the door and set the washer to Rinse and Spin. Run this program several times until you see no suds in the wash tub. If the LE code returns when the washer is empty, check the drain pump and filter for foreign objects. The error can also occur if you wash too many items at once or too heavy a set of items. Try doing a smaller load in the future.
If the error persists, then the tub motor, bearings, motor shaft or wiring may be damaged. Here is the parts diagram and one vendor's list of the replacement parts: http://www.searspartsdirect.com/lg-washer-parts/model-WM1814CW/3204/0153200/K0810333/00002.html . If your washer is under warranty, contact LG.
I hope this helps.
May 25, 2015 | LG Washing Machines
Need service manual for LG Washer wm1814cw looking to fix LE code
you can go to appliancerepairplanet.vstore.ca to get a sevice manual
Dec 13, 2010 | LG WM1814CW Front Load Washer
Washer gives the LE error when trying to spin. What is the LE error and how can I fix it?
Unplug machine, hold down the Start/Pause button 5 seconds while still unplugged. Plug back in and then do a rinse/spin to see if LE code come back.
Nov 19, 2010 | LG WM1814CW Front Load Washer
Le code appearing?
LE code can be tricky most of the time it ends up being the hall sensor.
Sep 19, 2010 | LG WM1814CW Front Load Washer
What does the LE error code mean
LE means 'Overload in Motor'. The manual says to 'Close the water tap. Unplug the power plug. Call for service.'
Straight from this washer's manual.
Hope this helps. =)
Oct 20, 2009 | LG WM1814CW Front Load Washer
LG front load washer says LE on the desplay
LE is overloaded motor- most likely speed/direction sensor.
Call 1-877-714-7486 for LG reset proceedure and verification test.
Sensor is inboard of motor removed from the back.
Hope this helps
Jul 02, 2009 | LG WM1814CW Front Load Washer
LG frontloader with lE code. Oh, what to do?
I just unplugged my washer for about 20 minutes and it has worked fine since. Hopefully, that will contiune for a L-O-N-G while. Good luck folks!
Apr 13, 2009 | LG WM1814CW Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
Le code appears during normal cycle
LG recommends unplugging the washer for 15 - 20
minutes to reset the microprocessor.
The most common cause for the LE error code is over-sudsing in the machine from using regular detergent instead of a high efficiency detergent. The HE detergents are designed for lower suds levels and enhanced cleaning performance in front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. LG recommends loading the washer until the clothes in the drum are no more than three-fourths of the way up the window of the door. This will allow them sufficient room for tumbling.
http://tclaundryrepair.com/
Feb 26, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
