Question about Sony KP-51WS500 51" Rear Projection Television
When i turn it on the screen turns green then blue and then shuts off
    Top Expert:
  • Sony Master
  • 14,553 Answers
This is one of a group of sets that had bad picture tubes (RED, GREEN AND BLUE).
The tubes are no longer available from Sony and only available on a rebuild basis---very expensive.
There is something easy that requires no parts you can try in an attempt to cure it. Takes about 15 minutes and I can tell you how and what to do.
If this is of interest to you rate this solution as very helpful and comment here and I will assist you.
SD TECH
Posted on Aug 30, 2010
  • 1 more comment
  • Peta han Sep 06, 2010
    how can i fix my tv? it is a sony kp 51ws500 and when i turn it on the screen is green with arcs on it. then after a few moments of being on it turns off by its self and the standby light flashes
  • matnae Sep 15, 2010
    I have the same problem and my TV has been just sitting collection dust for 3 years. What is the fix?
  • aharman3 Oct 02, 2010
    VERY HELPFUL!! Can you send me the solution please!
Peta Han - We had this problem and ultimately ended up replacing the TV. The TV would behave the same way with green arcs and then turns off. A few times we paid $75 (twice) to a technician who was able to come adjust the wired screws with a screwdriver. This would keep the TV on, but not really change the green archs. After doing that twice we gave up and bought a new TV. All the repair people said that we would not be able to buy a replacement 'tube' to fix it. Seems to be a problem with this Sony TV. Similar to this video posted on YouTube thought not exact: http://www.youtube.com/watch?v=hDgYOVDYV7Y
Posted on Sep 08, 2010
Wd-73737 wont turn on blinking green light
First is if you are able to get it to turn on and blue screen only appears it will shut down as no signal noted.
If you can get it on with Mitsubishi remote : Menu, 1,2,3 enter
This is the soft reset and the set also has a hard reset.
Try the soft reset first and let me know what happens.
Mar 09, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Need to clean lenses and do manual focus/alignment of guns on a VS-5055. How do I get access to them and adjust? Thank you.
the lenses are accessable by removing lower back of unit,clean them with a damp paper towel-wipe them off with a dry one.put back back on unit.
screen/focas controls are in front of unit.remove speaker grill remove black cover using phillips screwdriver.you will see 2 sets of controls.one row is focas.one row is screen controls.red,green,blue.turn each focas control slowly to get the clearest picture for each color.screen controls are touchy(if you turn then too high unit will shut off)if the black and white picture was good i would not adjust screen controls.if it was bad turn blue and green screens down all the way.picture is now red turn green up until it turns yellow then turn blue up until it turns white
Sep 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
Hitachi 46510 blue screen-Shuts down
Good Day, 6slimshandy9;
Try and look this;
Shuts down at turn on, LEDs D955 & D956 come on & turn off asap, the rest of the LEDs on power supply will go off slowly.
Cause: Found QEA6 (2315381) and QEA7(2315391) shorted in Blue CRT PWB.
I hope this was helpful, big IRISH. Or try unplugging the blue crt socket and if it turns off. If it stays on suspect bad CRT.
Jul 29, 2008 | Hitachi 46F510 46" Projection HDTV
Sony turns on and off again
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
216 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
