Question about Maytag MSD2454G Side by Side Refrigerator
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so I thawed it out and then it happened again about a week later so I assume there is a problem. The timer is working - it cycles into and out of defrost. The heater is working - it gets hot during defrost. I sprayed compressed air onto the thermostat during defrost when the fridge was at room temp after thawing it and the heater came on and turned off during the defrost cycle, and the fan is working. If the timer, heater and thermostat are all good then why do the coils keep freezing up. Does it need a recharge of coolant? Thanks a lot.
  • DERRICKDRINKWINE Jul 08, 2013
    DID YOU FIGURE THIS OUT MINE DOES THE EXACT SAME!
    IF SO PLEASE EMAIL ME DERRICKDRINKWINE@hOTMAIL.COM THNAKS MUCH
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Water leaking and freezing at bottom of freezer in side by side Maytag model # msd2454gr refridgerator.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
Ice build-up in lower freezer. We replaces the
warm between doors is normal. if hot then clean coils and if coils clean make sure condenser fan motor working thats the fan in the back compartment, however if warm thats good. did the evaporator coil freeze from top to btm is that why u replaced heater. if it was then could be heater,if the coil is only getting frost on half the coil,you could have a sealed system problem. is the evaporator motor working in the frz side if not,then that could be the problem.if coil is froze up it needs to be defrosted. did you defrost coil when you replaced heater,if not try defrosting coils and then wait about 12 hrs and see how it does.
Sep 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
SAMSUNG RB215LASH fridge coil iceing up
Don't think its a control board. I think you need to see if Samsung has a longer sealed system warranty. I think at this time the repair should fall back on Samsung 5 year sealed system. I can send you the service manual and the evaporator information if you like. The problem is most likely a defrost heater in the fresh food evaporator has become defective. And it cannot be replaced without removal of evaporator and heater together. Some idiot had the idea of weaving the defrost heater into the evaporator coils on your model. The heater is part of the evaporator. Which I would say now is part of the sealed system. I think you need to have a talk with your nearest Maytag service team. Samsung is a division of Maytag and because of the issue of the defrost heater being not replaceable without breaking into the sealed system Maytag may honor your concerns. Sorry I could not bring better news. But feel it's better to let you know. If you need me let me know, Thanks, Sea Breeze
Jul 18, 2009 | Samsung RB215LASH
MSD2454GR Side by Side refrigerator- freezer side fine, refrigerator side will not cool below 50 degrees; lots of condensation
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water is leaking from the freezer to thge floor. I is a side by side Maytag refrigerator
I had a simular problem - it is EASY to fix once you know what it is. "They" don't tell you that you should clean out the drain once a year..."they" would rather you call a repair man. Empty out the freezer side and remove the bottom panel inside the freezer. If you don't know how to do this google your fridge type and model number and you should be able to find directions to do so. In the very bottom is a drain that can get clogged with ice. Using a hair dryer and hot/warm water melt and gently break away all the ice. Poor hot/warm water over it till completely thawed out. What is supposed to happen with this drain is moisture is supposed to go to a pan under the fridge and evaporate. When it is clogged the water spills out onto the floor. If I can do this anyone can. I was about 50 years old and a woman when I first did this.
Jun 14, 2009 | Maytag MSD2656G Side by Side Refrigerator
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Maytag MSD2454GR
compressor relay shot. needs ground wire to frame of fridge also.
May 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Nov 16, 2007 | Maytag 23 cu. ft. Side-by-Side...
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Maytag MSD2454G Side by Side Refrigerator Logo
402 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
