Question about Kenmore Refrigerators
I have a kenmore 106.50503990 refrigerator. The water to the icemaker is OK, but the water dispenser is not flowing.
fridgetech
  • 473 Answers
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
Check to see that you do have water to the water valve on the fridge. You can disconnect right where the water line goes into the valve on the fridge. Next, if you can, check power at the valve while activating the water dispenser. If you have power at the valve when activating then the water valve is bad. Let me know what you find.
Posted on Oct 10, 2007
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
  • 103 Answers
SOURCE: Kenmore 106 50522 water leak from Icemaker
Hi: Usually if the ice maker malfunctions that bad it will keep running and flood bad. If your defrost drain is plugged it will puddle water. Without knowing how much water you see it is tough for me to say precisely. Does the ice bin have a big block of solid ice or cubes? If cubes I would guess it is the defrost drain at the bottom of the fridge. If the drain is clogged the water wont get to the pan to evaporate. If the defrost water has nowhere to go it will puddle. This would produce more water on the floor in a humid area than a desert like I live in. If so look at the bottom of the freezer in the back below the metal panel. Usually there are slots above it. There will be a hole at the bottom of a shallow rectangular funnel. Turn off the fridge and put your food in a cooler. Pour some warm clorox water in the hole, a fairly strong solution. It should eat out the mold that grows in the base of this non refrigerated line. If something like a frozen pea got in the line you might have to use a pipe cleaner to snake it out. Good luck with this, Jeff
Posted on Jun 01, 2009
  • 35 Answers
SOURCE: Kenmore Coldspot 106 54689300
DID YOUHOLD THE DISPENSER FOR A LONG TIME AND PURGE AIR ??? ARRE YOU GETTING ICE???
Posted on Jun 18, 2009
  • 670 Answers
SOURCE: kenmore 106 89482995- How to replace water pump?
Access will be from the rear at bottom. Pump found at Sears website at this link. Love those helpful service people !! link is long, but it works. i used copy and paste http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=10689482995&productCategoryId=0164160&brandId=0582&modelName=AUTOMATIC-ICE-MAKER&diagramPageId=00003&componentDescription=PUMP&documentId=P0306093&backToLink=Return to Sub Components list
Posted on Jul 01, 2009
I have a kenmore coldspot side by side water comes out dispenser but there is no water flow up to ice maker,also just replaced dual water celanoid
Hello, so you just replaced the water inlet valve correct? Here is a video on how to test the icemaker by removing the cover of the icemaker and connecting the L to the V water should immediatley come from the water inlet valve to the ice tray. If it did not and you heard the water valve actuate then there would be an issue with the icemaker in the unit. click this link http://www.youtube.com/watch?v=AlYCJr9dc3E if you have any further questions message me back Thanks
Rick
Sep 11, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore Refrig 51562 Side By Side; Icemaker leaks water underneat
you are going to have to replacwe the solinoid valve for the icemaker mbecause its leaking by
Feb 25, 2009 | Kenmore 51562 / 51564 / 51569
Water dispenser doesn't work but icemaker works fine
TAKE A HAIR DRIER AND HEAT UP THE RESEVOUR INSIDE OF THE REFFRIGERATOR BY THE OUTLET UNTIL THE WATER STARTS TO FLOW. GOOD LUCK
Jan 11, 2009 | Maytag MFI2568AE Side by Side French Door...
Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker problems
hi thanks for the question when you switched the wires around you checked the valves . tey are ok is the arm in the ice maker down check that if that's ok then the problem is with ice maker thanks for the question the appliance doc
Sep 23, 2008 | Kenmore 53642 / 53644 Side by Side...
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
May 18, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
